[GRASS-user] Re: grass-user Digest, Vol 64, Issue 2
Margherita Di Leo diregola at gmail.com
Wed Aug 3 06:09:46 EDT 2011
fixed in r47364.
Thanks for patience.
madi
Hello! I am trying to run r.basin for some analysis and it start promising
> but it end badly:
> r.basin.py map=dem_fill at harta prefix=a easting=491896.20
> northing=659955.69
> threshold=900
> Removing raster <MASK>
> Raster map <MASK> not found
> <MASK> nothing removed
> SECTION 1a (of 5): Initiating Memory.
> SECTION 1b (of 5): Determining Offmap Flow.
> SECTION 2: A * Search.
> SECTION 3: Accumulating Surface Flow with SFD.
> SECTION 4: Watershed determination.
> SECTION 5: Closing Maps.
> Writing out only positive flow accumulation values.
> Cells with a likely underestimate for flow accumulation can no longer be
> identified.
> Traceback (most recent call last):
>  File "/usr/lib/grass64/scripts/r.basin.py", line 427, in
> <module>
>    sys.exit(main())
>  File "/usr/lib/grass64/scripts/r.basin.py", line 133, in
> main
>    grass.run_command('r.stream.extract', elevation =
> r_elevation, accumulation = r_accumulation, threshold = th,
> d8cut = 'infinity', mexp = 0, stream_rast = r_stream_e,
> stream_vect = v_stream_e, direction = r_drainage_e, flags
> ='-o')
>  File "/usr/lib/grass64/etc/python/grass/script/core.py",
> line 186, in run_command
>    ps = start_command(*args, **kwargs)
> line 167, in start_command
>    args = make_command(prog, flags, overwrite, quiet,
> verbose, **options)
> line 124, in make_command
>    raise ScriptError("'-' is not a valid flag")
> grass.script.core.ScriptError: "'-' is not a valid flag"
> (Mon Aug  1 21:19:09 2011) Command finished (2 sec)
> I must mention that I have Grass64 installed from
> https://launchpad.net/~grass/+archive/grass-stable<https://launchpad.net/%7Egrass/+archive/grass-stable>on Ubuntu Maverick and
> all dependencies needed ( I have managed to run separately almost every
> command but I have in total  22 basins)
> Please could someone point me in the right direction ?
> Bogdan Rosca
> -------------- next part --------------
> An HTML attachment was scrubbed...
> URL:
> http://lists.osgeo.org/pipermail/grass-user/attachments/20110801/f58ffcde/attachment-0001.html
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110803/0f93a374/attachment.html
