[GRASS-user] v.to.rast
Freddy López freddy.vate01 at gmail.com
Wed Aug 3 15:11:21 EDT 2011
Dear Salvatore,
I have a similar issue. Did you fix the problem?
Cheers.
On Fri, Jul 29, 2011 at 07:22, Markus Metz <
markus.metz.giswork en googlemail.com> wrote:
> Salvatore Mellino wrote:
> > Hi,
> > I have a problem with v.to.rast. I have a vector of an Italian region
> (Campania), when I convert it to raster I lose the quality of boundary. Is
> it a problem of resolution? How can I fix the problem?
> If you want to convert the boundaries to rasterized lines instead of
> the area, you would first need to convert the boundaries to lines and
> then convert the vector lines to raster.
> Also make sure that the computational region is correctly set (extents
> at least overlapping with the vector map and the desired resolution).
> Markus M
> grass-user mailing list
> grass-user en lists.osgeo.org
> http://lists.osgeo.org/mailman/listinfo/grass-user
«But Gwindor answered: 'The doom lies in yourself, not in your name.'»
JRR Tolkien
------------ próxima parte ------------
Se ha borrado un adjunto en formato HTML...
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110803/da5d0343/attachment.html
