[GRASS-user] Re: r.li.setup
Markus Neteler neteler at osgeo.org
Thu Aug 11 17:41:09 EDT 2011
On Sat, Jul 30, 2011 at 6:10 AM, Ravinder Singh Bhalla
<rsbhalla at gmail.com> wrote:
> Dear All,
> I've been trying to send this to the list for the past few weeks, seems my
> mails are being blocked. Anyway, here's another attempt.
> I've been trying to use the r.li suite in a landscape ecology course and
> found the r.li.setup fails to create configuration files if one tries to
> setup the sampling frame by drawing regions or by using vector layers. The
> moving window, however, works.
> Any suggestions on how to overcome this?
Perhaps you could use
http://grass.osgeo.org/wiki/Addons#r.diversity
(it internally has a createConfFile() function)
Markus
which may be easier to use.
> Thanks,
> Ravi
> Config file for region (2 regions were attempted but the input dialoge did
> not allow me to digitise the regions of interest.)
> SAMPLINGFRAME 0|0|1|1
> MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|one
> MASKEDSAMPLEAREA 0.0|0.0|1.0|1.0|two
> Config file for vector input (vector comprised of 6 polygons)
> On Sunday 03 April 2011 05:22 AM, Hamish wrote:
>> Nani wrote:
>>> r.li.setup
>>> How to install, Where to find it, how is it provided,
>> r.li.* is not provided in WinGrass. Only on UNIX builds (Mac or
>> Linux). If you want to use these modules, you may also try the
>> Cygwin build of GRASS for MS Windows, or try the older r.le
>> modules.
>>> what is it supposed this command do.
>> see  http://grass.osgeo.org/grass64/manuals/html64_user/r.li.html
>> Hamish
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
