[GRASS-user] troubles installing r.fuzzy.system add-on on
Mac OSX (GRASS 6.4.1) + NVIZ compilation error
Michael Barton
Michael.Barton at asu.edu
Thu Aug 18 18:10:30 EDT 2011
Guillaume,
You might try my binaries for GRASS 7 (and other versions). You can get them at <hhttp://www.public.asu.edu/~cmbarton/files/grass_mac/OSX10.6-snowleopard/>. There is an accompanying text file (frameworks.txt) that tells which version of William's frameworks are needed.
If these work, you can try a compilation. Here is my configure string:
./configure --with-freetype --with-freetype-includes="/Library/Frameworks/FreeType.framework/unix/include/freetype2 /Library/Frameworks/FreeType.framework/unix/include" --with-freetype-libs=/Library/Frameworks/FreeType.framework/unix/lib --with-gdal=/Library/Frameworks/GDAL.framework/Programs/gdal-config --with-proj --with-proj-includes=/Library/Frameworks/PROJ.framework/unix/include --with-proj-libs=/Library/Frameworks/PROJ.framework/unix/lib --with-proj-share=/Library/Frameworks/PROJ.framework/Resources/proj --with-geos=/Library/Frameworks/GEOS.framework/Programs/geos-config --with-jpeg-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-jpeg-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-png-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-png-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-tiff-includes=/Library/Frameworks/UnixImageIO.framework/unix/include --with-tiff-libs=/Library/Frameworks/UnixImageIO.framework/unix/lib --with-cairo --with-cairo-includes="/Library/Frameworks/cairo.framework/unix/include/cairo /Library/Frameworks/cairo.framework/unix/include" --with-cairo-libs=/Library/Frameworks/cairo.framework/unix/lib --with-cairo-ldflags="-lcairo" --without-postgres --without-mysql --with-odbc --with-sqlite --with-sqlite-libs=/Library/Frameworks/SQLite3.framework/unix/lib --with-sqlite-includes=/Library/Frameworks/SQLite3.framework/unix/include --with-fftw-includes=/Library/Frameworks/FFTW3.framework/unix/include --with-fftw-libs=/Library/Frameworks/FFTW3.framework/unix/lib --with-x --with-cxx --with-opengl=aqua --without-readline --prefix=/Applications/GRASS --enable-macosx-app --with-python --with-wxwidgets=/usr/local/lib/wxPython-unicode-2.8.12.0/bin/wx-config --with-tcltk-includes="/Library/Frameworks/Tcl.framework/Headers /Library/Frameworks/Tk.framework/Headers /Library/Frameworks/Tk.framework/PrivateHeaders" --with-tcltk-libs="/usr/local/tcltk_active/lib" --with-macosx-archs="i386 x86_64"
For TclTk, I use the ActiveStates binary for TclTk 8.5 aqua but have created links to it in a special directory in /usr/local, following William's suggestion. Otherwise, you need to edit platform_make. You also need to edit bundle_make to create a package that includes wxPython if you want to distribute this to others. William (or I) can give you directions on how to do so if you want to do it.
Here are the instructions for dealing with TclTk after you install the ActiveStates 8.5 binary (8.6 won't work I'm told).
Create a folder...
/usr/local/tcltk_active/lib/...
make links to the ActiveTcl framework binaries
libtcl.dylib -> /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl
libtcl8.5.dylib -> /Library/Frameworks/Tcl.framework/Versions/8.5/Tcl
libtclstub8.5.a -> /Library/Frameworks/Tcl.framework/Versions/8.5/libtclstub8.5.a
libtk.dylib -> /Library/Frameworks/Tk.framework/Versions/8.5/Tk
libtk8.5.dylib -> /Library/Frameworks/Tk.framework/Versions/8.5/Tk
libtkstub8.5.a -> /Library/Frameworks/Tk.framework/Versions/8.5/libtkstub8.5.a
Then configure grass with:
Tk.framework/PrivateHeaders" --with-tcltk-libs=/usr/local/tcltk_active/
lib
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax: 480-965-7671 (SHESC), 480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Aug 19, 2011, at 9:00 AM, <grass-user-request at lists.osgeo.org> <grass-user-request at lists.osgeo.org> wrote:
> Date: Thu, 18 Aug 2011 10:22:54 +0800
> From: <Guillaume.Duclaux at csiro.au>
> Subject: Re: [GRASS-user] troubles installing r.fuzzy.system add-on on
> To: <kyngchaos at kyngchaos.com>
> Cc: grass-user at lists.osgeo.org, jarekj at amu.edu.pl
> Message-ID: <841C6F38-10EE-48B0-B295-E13725838EEE at csiro.au>
> Content-Type: text/plain; charset="Windows-1252"
> Thanks for the tip. I'll give a try at modbuild.
> Although, Jarek advised me to upgrade to Grass 7.0, which I tried but encountered a known compilation problem with NVIZ (something related to Tk).
> GRASS GIS compilation log
> Started compilation: Wed 17 Aug 2011 22:50:58 WST
> Errors in:
> /usr/local/src/grass_trunk/visualization/nviz
> This seems similar to this post:
> http://osgeo-org.1803224.n2.nabble.com/wxnviz-on-mac-osx-grass7-0-td5439863.html
> I can't find out the fix for this one in the post. I looked in the macOSX/readme and followed the TclTk guidance (ie: installed TclTk 8.5 from ActiveState, created the links), but the compilation still fails.
