[GRASS-user] bash script error
Mon Aug 22 09:31:14 EDT 2011
Rebecca Bennett wrote:
> r.mapcalc '${BKG} = if(isnull(modern_mask at Brovey),${MAP},0)'
> but it ends with the error
> Invalid map <${MAP}>
> Can
>  anyone tell me how I should include calls to the map and name a
> derivative using the original raster name? I have used this syntax with
> success before so have not be able to troubleshoot this.
You need to use double quotes around the r.mapcalc expression.
Single-quoted strings take everything up to the next single quote
literally, while double-quoted strings expand variable substitutions.
