[GRASS-user] d.vector problems in GRASS-7
Andres Kuusk andres at aai.ee
Wed Aug 24 04:55:41 EDT 2011
Hi!
I am using the SVN version of GRASS-7 for a while.
In r45123 I had a problem of using selection options for displaying
vectors, which I reported in ticket #1266.
Since that time several modifications of vector modules has been done,
however things turn worse and worse. I have tested r45168, r45179,
r45185, r45214, r45303, r45362, r45396, r45405, r45592, r47521, r47600,
r47640, r47770, r47865.
In the early versions just vectors disappeard if I turned on some
selection criterion. Since r46317 I got error message which I reported as
a comment to the ticket #1266.
Since r47521 the rendering of a vector fails at all.
Therefore I still use r44607.
I have tested GRASS-7 from svn-trunc on two Linux PC-s,
openSUSE-11.4, Linux 2.6.37.6-0.7-pae i686 i386 and
openSUSE-11.2, Linux 2.6.31.14-0.8-desktop6 i686 i386
# svn checkout https://svn.osgeo.org/grass/grass/trunk grass_trunk
# ./configure --enable-shared --without-mysql --without-sqlite --with-gdal
--without-fftw --with-postgres --with-postgres-includes=/usr/include/pgsql
--with-freetype-includes=/usr/include/freetype2
--with-freetype-libs=/usr/lib --with-geos=/usr/local/bin/geos-config
# make
or
# make clean
# svn cleanup
# svn up
# make
In openSUSE-11.4:
# ./bin.i686-pc-linux-gnu/grass70
I open a raster - OK
I try to open a vector:
Command 'd.vect color=165:42:42 map=cks at CHRIS layer=-1
type=boundary,area fcolor=none' failed
Details: Unable read topology for area 2
ERROR: Rendering failed
I try to open another vector:
Command 'd.vect color=165:42:42 map=eraldised_8m_buf at CHRIS
layer=-1 type=area fcolor=none' failed
Details: G_realloc: unable to allocate 3720975616 bytes of
memory at struct_alloc.c:378
Both vectors are correct and can be used in r44607.
I like the GRASS-7 and obviosly several new features are introduced
or got working since r44607. Unfortunately I still have to use rather old
version wich has its own problems.
Is it only a problem of my installation or maybe the same problem is there
on other Linux PC-s as well?
Andres Kuusk
Tartu Observatory, Estonia
