[GRASS-user] Flow accumulation from r.stream
Joshua Arnott josh at snorfalorpagus.net
Fri Aug 26 10:21:25 EDT 2011
Hi grass-users,
Is it possible to generate a flow accumulation map using r.stream,
similar to the one r.watershed produces? I see r.stream.extract outputs
a drainage direction raster, from which the accumulation could be
calculated, but I can't see any obvious way of doing this.
Regards,
Josh
