[GRASS-user] Re: r.fillnulls for large area
pkscwc
pkscwc at gmail.com
Sat Dec 3 02:39:51 EST 2011
Dear Nick,
I am working on SRTM rasters of resolution 1km, 500m, 250m and recently 90m
using GRASS for long and had countered the problem being faced by you.
My workaround is given below and as a by-product you may get a very nice
coastline vector/raster also.
1. I have converted all the nulls with r.mapcalc to -160 using the formula
C=if(A, if(isnull(B),-160,B))
Where,
A: region of interest
B: original srtm raster with nulls for sea and holes
C: Output map in which nulls have been converted to -160.
(Why -160, because in my map, as from my human memory, the lowest value was
-70. I just chose a value lower than this value. We will need it later on to
convert back them as holes for r.fillnulls to work upon.)
A sample from the history file of the raster is produced below:
Sun Aug 1 17:49:10 2010
test5
PERMANENT
pks
raster
generated by r.mapcalc
if(test_nL_region at PERMANENT, if(isnull(ib2 at PERMANENT), -160, ib2 at PERMANENT))
A: test_nL_region
This raster map is a region of my interest out the big srtm raster converted
from a vector. Grass has a command , which converts the current region to a
vector file.
Again, the sample from the history file of the raster is produced below:
ed Jul 28 10:09:42 2010
test_nL_region
PERMANENT
pks
raster
Vector Map: nL_region at PERMANENT in mapset PERMANENT
Original scale from vector map: 1:1
generated by v.to.rast
v.to.rast input="nL_region at PERMANENT" output="test_nL_region" use="c\
at" type="point,line,area" layer=1 value=1 rows=4096
nL_region:
Again, the sample from the history file of the vector is produced below:
COMMAND: v.in.region output="nL_region" type="area" cat=1
GISDBASE: /home/pks/renamed_grassdata
LOCATION: newLocation MAPSET: PERMANENT USER: pks DATE: Wed Jul 28 09:53:43
2010
So, now we have -160s all around , i.e. the sea and holes on land.
Now use the r.reclass.area feature to differentiate sea from holes on land.
A sample from my recent work is given below:
Tue Nov 8 13:55:47 2011
bi_reclassed3_area.recl
work2
rdcgis1
reclass
Reclassified map based on:
Map [bi_reclassed3.clump.bi_reclassed3_area] in mapset [work2]
generated by r.reclass
I am using GRASS7 and in the history given above , all the parameters are
not available.
In my case , I used 1 billion hectare as "greater than area" parameter to
bring out the sea , land , and holes in land in different categories.
Thereafter, use mask and pick up the landmass with holes in land , which you
want to fill.
Just remember to convert back the -160 to null again.
I felt that r.fillnulls works best when the nulls have values around them.
By the way, CGIAR provides holes-filled-SRTM-raster.You may like to read
their literature for understanding the algorithms used to fill the nulls.
It's good and useful.
Try this link for downloading clean rasters of your area of interest:
http://srtm.csi.cgiar.org/SELECTION/inputCoord.asp
Hope, it helps.
Some of my observations are listed below:
1. If the system lacks RAM, then increase patience.
2. If the system lacks hard-disk space, don't go for GIS.
3. Learn python.
View this message in context: http://osgeo-org.1803224.n2.nabble.com/r-fillnulls-for-large-area-tp7047337p7057352.html
Sent from the Grass - Users mailing list archive at Nabble.com.
