[GRASS-user] Error trying to mosaic two images
femgo
femgo27 at gmail.com
Tue Dec 6 07:57:56 EST 2011
Thanks for the help guys.
I used r.patch, it´s the better solution here.
2011/12/5 Glynn Clements <glynn at gclements.plus.com>
> Hamish wrote:
> > > syntax error, unexpected '@', expecting '='
> > > Parse error
> > > C:/Arquivos de programas/GRASS6.4RC1/scripts/i.image.mosaic: line 98:
> > the r.mapcalc call apparently does not like the @mapset in the input
> > names. I suspect a little \"quoting\" of the variables within the mapcalc
> > statement will help.
> Quoting will make r.mapcalc accept a qualified name on the LHS of the
> "="; however, the name must still refer to the current mapset.
> But r.mapcalc is the least of the problems. i.image.mosaic
> fundamentally expects the map names to be unqualified.
Felipe Moreira Gonçalves
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111206/d00177bc/attachment.html
