[GRASS-user] Getting error to compile source code of r.watershed using osgeo4w
Sandip Maity sandip.stesalit at gmail.com
Wed Dec 7 02:21:02 EST 2011
Dear Grass user,
I am getting this error at the time of compilation the source code of
r.watershed.
Please see the error report.
Administrator at SOFT10
/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed
$ make
make -C ram || echo
/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/ram
>> /c/OSGeo4W/apps/grass/grass-6.5.svn/error.log
make[1]: Entering directory
`/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/ram'
../../../include/Make/Module.make:25: warning: overriding commands for
target `install'
../../../include/Make/Rules.make:90: warning: ignoring old commands
for target `install'
makefile:13: warning: overriding commands for target `htmletc'
../../../include/Make/Html.make:53: warning: ignoring old commands for
target `htmletc'
test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
gcc -I/c/OSGeo4W/apps/grass/grass-6.5.svn/include -I/c/OSGeo4W/include
-g -O2  -I/c/OSGeo4W/include     -DPACKAGE=\""grassmods"\"
-I/c/OSGeo4W/apps/grass/grass-6.5.svn/include -o
OBJ.i686-pc-mingw32/close_maps.o -c close_maps.c
OBJ.i686-pc-mingw32/close_maps2.o -c close_maps2.c
OBJ.i686-pc-mingw32/def_basin.o -c def_basin.c
OBJ.i686-pc-mingw32/do_astar.o -c do_astar.c
OBJ.i686-pc-mingw32/do_cum.o -c do_cum.c
OBJ.i686-pc-mingw32/find_pour.o -c find_pour.c
OBJ.i686-pc-mingw32/flag_clr_all.o -c flag_clr_all.c
OBJ.i686-pc-mingw32/flag_create.o -c flag_create.c
OBJ.i686-pc-mingw32/flag_destroy.o -c flag_destroy.c
OBJ.i686-pc-mingw32/flag_get.o -c flag_get.c
OBJ.i686-pc-mingw32/flag_set.o -c flag_set.c
OBJ.i686-pc-mingw32/flag_unset.o -c flag_unset.c
OBJ.i686-pc-mingw32/haf_side.o -c haf_side.c
OBJ.i686-pc-mingw32/init_vars.o -c init_vars.c
OBJ.i686-pc-mingw32/main.o -c main.c
OBJ.i686-pc-mingw32/no_stream.o -c no_stream.c
OBJ.i686-pc-mingw32/over_cells.o -c over_cells.c
OBJ.i686-pc-mingw32/ramseg.o -c ramseg.c
OBJ.i686-pc-mingw32/sg_factor.o -c sg_factor.c
OBJ.i686-pc-mingw32/slope_len.o -c slope_len.c
OBJ.i686-pc-mingw32/split_str.o -c split_str.c
OBJ.i686-pc-mingw32/usage.o -c usage.c
gcc -L/c/OSGeo4W/apps/grass/grass-6.5.svn/lib
-Wl,--export-dynamic,--enable-runtime-pseudo-reloc  -L/c/OSGeo4W/lib
-L/osgeo4w/usr/src/grass6_devel/mswindows/osgeo4w/lib     -o
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.ram.exe
OBJ.i686-pc-mingw32/close_maps.o OBJ.i686-pc-mingw32/close_maps2.o
OBJ.i686-pc-mingw32/def_basin.o OBJ.i686-pc-mingw32/do_astar.o
OBJ.i686-pc-mingw32/do_cum.o OBJ.i686-pc-mingw32/find_pour.o
OBJ.i686-pc-mingw32/flag_clr_all.o OBJ.i686-pc-mingw32/flag_create.o
OBJ.i686-pc-mingw32/flag_destroy.o OBJ.i686-pc-mingw32/flag_get.o
OBJ.i686-pc-mingw32/flag_set.o OBJ.i686-pc-mingw32/flag_unset.o
OBJ.i686-pc-mingw32/haf_side.o OBJ.i686-pc-mingw32/init_vars.o
OBJ.i686-pc-mingw32/main.o OBJ.i686-pc-mingw32/no_stream.o
OBJ.i686-pc-mingw32/over_cells.o OBJ.i686-pc-mingw32/ramseg.o
OBJ.i686-pc-mingw32/sg_factor.o OBJ.i686-pc-mingw32/slope_len.o
OBJ.i686-pc-mingw32/split_str.o OBJ.i686-pc-mingw32/usage.o
../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o -lgrass_gis.6.5.svn
-lgrass_datetime.6.5.svn -lxdr -liberty -lws2_32    -lz   -lintl
gcc.exe: ../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o: No such file or directory
make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.ram.exe]
Error 1
make[1]: Leaving directory
make -C seg || echo
/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/seg
`/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/seg'
target `install'
target `htmletc'
OBJ.i686-pc-mingw32/bseg_close.o -c bseg_close.c
OBJ.i686-pc-mingw32/bseg_get.o -c bseg_get.c
OBJ.i686-pc-mingw32/bseg_open.o -c bseg_open.c
OBJ.i686-pc-mingw32/bseg_put.o -c bseg_put.c
OBJ.i686-pc-mingw32/bseg_read.o -c bseg_read.c
OBJ.i686-pc-mingw32/bseg_write.o -c bseg_write.c
OBJ.i686-pc-mingw32/cseg_close.o -c cseg_close.c
OBJ.i686-pc-mingw32/cseg_get.o -c cseg_get.c
OBJ.i686-pc-mingw32/cseg_open.o -c cseg_open.c
OBJ.i686-pc-mingw32/cseg_put.o -c cseg_put.c
OBJ.i686-pc-mingw32/cseg_read.o -c cseg_read.c
OBJ.i686-pc-mingw32/cseg_write.o -c cseg_write.c
OBJ.i686-pc-mingw32/dseg_close.o -c dseg_close.c
OBJ.i686-pc-mingw32/dseg_get.o -c dseg_get.c
OBJ.i686-pc-mingw32/dseg_open.o -c dseg_open.c
OBJ.i686-pc-mingw32/dseg_put.o -c dseg_put.c
OBJ.i686-pc-mingw32/dseg_read.o -c dseg_read.c
OBJ.i686-pc-mingw32/dseg_write.o -c dseg_write.c
OBJ.i686-pc-mingw32/sseg_close.o -c sseg_close.c
OBJ.i686-pc-mingw32/sseg_get.o -c sseg_get.c
OBJ.i686-pc-mingw32/sseg_open.o -c sseg_open.c
OBJ.i686-pc-mingw32/sseg_put.o -c sseg_put.c
/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.seg.exe
OBJ.i686-pc-mingw32/bseg_close.o OBJ.i686-pc-mingw32/bseg_get.o
OBJ.i686-pc-mingw32/bseg_open.o OBJ.i686-pc-mingw32/bseg_put.o
OBJ.i686-pc-mingw32/bseg_read.o OBJ.i686-pc-mingw32/bseg_write.o
OBJ.i686-pc-mingw32/cseg_close.o OBJ.i686-pc-mingw32/cseg_get.o
OBJ.i686-pc-mingw32/cseg_open.o OBJ.i686-pc-mingw32/cseg_put.o
OBJ.i686-pc-mingw32/cseg_read.o OBJ.i686-pc-mingw32/cseg_write.o
OBJ.i686-pc-mingw32/do_cum.o OBJ.i686-pc-mingw32/dseg_close.o
OBJ.i686-pc-mingw32/dseg_get.o OBJ.i686-pc-mingw32/dseg_open.o
OBJ.i686-pc-mingw32/dseg_put.o OBJ.i686-pc-mingw32/dseg_read.o
OBJ.i686-pc-mingw32/dseg_write.o OBJ.i686-pc-mingw32/find_pour.o
OBJ.i686-pc-mingw32/over_cells.o OBJ.i686-pc-mingw32/sg_factor.o
OBJ.i686-pc-mingw32/slope_len.o OBJ.i686-pc-mingw32/split_str.o
OBJ.i686-pc-mingw32/sseg_close.o OBJ.i686-pc-mingw32/sseg_get.o
OBJ.i686-pc-mingw32/sseg_open.o OBJ.i686-pc-mingw32/sseg_put.o
-lgrass_segment.6.5.svn -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn
-lxdr -liberty -lws2_32    -lz   -lintl    -lxdr -liberty -lws2_32
-lz
make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.seg.exe]
Error 1
make -C front || echo
/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/front
`/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/front'
target `install'
/c/OSGeo4W/apps/grass/grass-6.5.svn/bin/r.watershed.exe
make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/bin/r.watershed.exe] Error 1
I cant resolve the issues and also not understanding the error also.
please help me to solve this.
regards.
Sandip
