[GRASS-user] Getting error to compile source code of r.watershed
using osgeo4w
Markus Metz
markus.metz.giswork at googlemail.com
Thu Dec 8 05:00:33 EST 2011
On Wed, Dec 7, 2011 at 8:21 AM, Sandip Maity <sandip.stesalit at gmail.com> wrote:
> Dear Grass user,
> I am getting this error at the time of compilation the source code of
> r.watershed.
You should first follow the compile instructions on the wiki [1] and
compile all of GRASS before you compile a single module (which is in
this case not necessary because it is compiled with the rest of
GRASS). Compilation of GRASS must finish successfully without errors.
You should definitively not touch the make system or change some
crucial variables by hand.
Markus M
[1] https://trac.osgeo.org/grass/wiki/CompileOnWindows
> Please see the error report.
> Administrator at SOFT10
> /c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed
> $ make
> make -C ram || echo
> /c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/ram
>>> /c/OSGeo4W/apps/grass/grass-6.5.svn/error.log
> make[1]: Entering directory
> `/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/ram'
> ../../../include/Make/Module.make:25: warning: overriding commands for
> target `install'
> ../../../include/Make/Rules.make:90: warning: ignoring old commands
> for target `install'
> makefile:13: warning: overriding commands for target `htmletc'
> ../../../include/Make/Html.make:53: warning: ignoring old commands for
> target `htmletc'
> test -d OBJ.i686-pc-mingw32 || mkdir -p OBJ.i686-pc-mingw32
> gcc -I/c/OSGeo4W/apps/grass/grass-6.5.svn/include -I/c/OSGeo4W/include
> -g -O2 -I/c/OSGeo4W/include -DPACKAGE=\""grassmods"\"
> -I/c/OSGeo4W/apps/grass/grass-6.5.svn/include -o
> OBJ.i686-pc-mingw32/close_maps.o -c close_maps.c
> OBJ.i686-pc-mingw32/close_maps2.o -c close_maps2.c
> OBJ.i686-pc-mingw32/def_basin.o -c def_basin.c
> OBJ.i686-pc-mingw32/do_astar.o -c do_astar.c
> OBJ.i686-pc-mingw32/do_cum.o -c do_cum.c
> OBJ.i686-pc-mingw32/find_pour.o -c find_pour.c
> OBJ.i686-pc-mingw32/flag_clr_all.o -c flag_clr_all.c
> OBJ.i686-pc-mingw32/flag_create.o -c flag_create.c
> OBJ.i686-pc-mingw32/flag_destroy.o -c flag_destroy.c
> OBJ.i686-pc-mingw32/flag_get.o -c flag_get.c
> OBJ.i686-pc-mingw32/flag_set.o -c flag_set.c
> OBJ.i686-pc-mingw32/flag_unset.o -c flag_unset.c
> OBJ.i686-pc-mingw32/haf_side.o -c haf_side.c
> OBJ.i686-pc-mingw32/init_vars.o -c init_vars.c
> OBJ.i686-pc-mingw32/main.o -c main.c
> OBJ.i686-pc-mingw32/no_stream.o -c no_stream.c
> OBJ.i686-pc-mingw32/over_cells.o -c over_cells.c
> OBJ.i686-pc-mingw32/ramseg.o -c ramseg.c
> OBJ.i686-pc-mingw32/sg_factor.o -c sg_factor.c
> OBJ.i686-pc-mingw32/slope_len.o -c slope_len.c
> OBJ.i686-pc-mingw32/split_str.o -c split_str.c
> OBJ.i686-pc-mingw32/usage.o -c usage.c
> gcc -L/c/OSGeo4W/apps/grass/grass-6.5.svn/lib
> -Wl,--export-dynamic,--enable-runtime-pseudo-reloc -L/c/OSGeo4W/lib
> -L/osgeo4w/usr/src/grass6_devel/mswindows/osgeo4w/lib -o
> /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.ram.exe
> OBJ.i686-pc-mingw32/close_maps.o OBJ.i686-pc-mingw32/close_maps2.o
> OBJ.i686-pc-mingw32/def_basin.o OBJ.i686-pc-mingw32/do_astar.o
> OBJ.i686-pc-mingw32/do_cum.o OBJ.i686-pc-mingw32/find_pour.o
> OBJ.i686-pc-mingw32/flag_clr_all.o OBJ.i686-pc-mingw32/flag_create.o
> OBJ.i686-pc-mingw32/flag_destroy.o OBJ.i686-pc-mingw32/flag_get.o
> OBJ.i686-pc-mingw32/flag_set.o OBJ.i686-pc-mingw32/flag_unset.o
> OBJ.i686-pc-mingw32/haf_side.o OBJ.i686-pc-mingw32/init_vars.o
> OBJ.i686-pc-mingw32/main.o OBJ.i686-pc-mingw32/no_stream.o
> OBJ.i686-pc-mingw32/over_cells.o OBJ.i686-pc-mingw32/ramseg.o
> OBJ.i686-pc-mingw32/sg_factor.o OBJ.i686-pc-mingw32/slope_len.o
> OBJ.i686-pc-mingw32/split_str.o OBJ.i686-pc-mingw32/usage.o
> ../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o -lgrass_gis.6.5.svn
> -lgrass_datetime.6.5.svn -lxdr -liberty -lws2_32 -lz -lintl
> gcc.exe: ../../../lib/gis/OBJ.i686-pc-mingw32/fmode.o: No such file or directory
> make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.ram.exe]
> Error 1
> make[1]: Leaving directory
> make -C seg || echo
> /c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/seg
> `/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/seg'
> target `install'
> target `htmletc'
> OBJ.i686-pc-mingw32/bseg_close.o -c bseg_close.c
> OBJ.i686-pc-mingw32/bseg_get.o -c bseg_get.c
> OBJ.i686-pc-mingw32/bseg_open.o -c bseg_open.c
> OBJ.i686-pc-mingw32/bseg_put.o -c bseg_put.c
> OBJ.i686-pc-mingw32/bseg_read.o -c bseg_read.c
> OBJ.i686-pc-mingw32/bseg_write.o -c bseg_write.c
> OBJ.i686-pc-mingw32/cseg_close.o -c cseg_close.c
> OBJ.i686-pc-mingw32/cseg_get.o -c cseg_get.c
> OBJ.i686-pc-mingw32/cseg_open.o -c cseg_open.c
> OBJ.i686-pc-mingw32/cseg_put.o -c cseg_put.c
> OBJ.i686-pc-mingw32/cseg_read.o -c cseg_read.c
> OBJ.i686-pc-mingw32/cseg_write.o -c cseg_write.c
> OBJ.i686-pc-mingw32/dseg_close.o -c dseg_close.c
> OBJ.i686-pc-mingw32/dseg_get.o -c dseg_get.c
> OBJ.i686-pc-mingw32/dseg_open.o -c dseg_open.c
> OBJ.i686-pc-mingw32/dseg_put.o -c dseg_put.c
> OBJ.i686-pc-mingw32/dseg_read.o -c dseg_read.c
> OBJ.i686-pc-mingw32/dseg_write.o -c dseg_write.c
> OBJ.i686-pc-mingw32/sseg_close.o -c sseg_close.c
> OBJ.i686-pc-mingw32/sseg_get.o -c sseg_get.c
> OBJ.i686-pc-mingw32/sseg_open.o -c sseg_open.c
> OBJ.i686-pc-mingw32/sseg_put.o -c sseg_put.c
> /c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.seg.exe
> OBJ.i686-pc-mingw32/bseg_close.o OBJ.i686-pc-mingw32/bseg_get.o
> OBJ.i686-pc-mingw32/bseg_open.o OBJ.i686-pc-mingw32/bseg_put.o
> OBJ.i686-pc-mingw32/bseg_read.o OBJ.i686-pc-mingw32/bseg_write.o
> OBJ.i686-pc-mingw32/cseg_close.o OBJ.i686-pc-mingw32/cseg_get.o
> OBJ.i686-pc-mingw32/cseg_open.o OBJ.i686-pc-mingw32/cseg_put.o
> OBJ.i686-pc-mingw32/cseg_read.o OBJ.i686-pc-mingw32/cseg_write.o
> OBJ.i686-pc-mingw32/do_cum.o OBJ.i686-pc-mingw32/dseg_close.o
> OBJ.i686-pc-mingw32/dseg_get.o OBJ.i686-pc-mingw32/dseg_open.o
> OBJ.i686-pc-mingw32/dseg_put.o OBJ.i686-pc-mingw32/dseg_read.o
> OBJ.i686-pc-mingw32/dseg_write.o OBJ.i686-pc-mingw32/find_pour.o
> OBJ.i686-pc-mingw32/over_cells.o OBJ.i686-pc-mingw32/sg_factor.o
> OBJ.i686-pc-mingw32/slope_len.o OBJ.i686-pc-mingw32/split_str.o
> OBJ.i686-pc-mingw32/sseg_close.o OBJ.i686-pc-mingw32/sseg_get.o
> OBJ.i686-pc-mingw32/sseg_open.o OBJ.i686-pc-mingw32/sseg_put.o
> -lgrass_segment.6.5.svn -lgrass_gis.6.5.svn -lgrass_datetime.6.5.svn
> -lxdr -liberty -lws2_32 -lz -lintl -lxdr -liberty -lws2_32
> -lz
> make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/etc/r.watershed.seg.exe]
> Error 1
> make -C front || echo
> /c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/front
> `/c/osgeo4w/usr/src/grass-6.5.svn_src_snapshot_2011_12_03/raster/r.watershed/front'
> target `install'
> /c/OSGeo4W/apps/grass/grass-6.5.svn/bin/r.watershed.exe
> make[1]: *** [/c/OSGeo4W/apps/grass/grass-6.5.svn/bin/r.watershed.exe] Error 1
> I cant resolve the issues and also not understanding the error also.
> please help me to solve this.
> regards.
> Sandip
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
