[GRASS-user] v.rast.stats (r.category) fail?
    Annalisa Minelli
    annagrass6 at gmail.com
    Sat Dec 10 07:17:32 EST 2011
Hi Markus,
I'm usgin GRASS65 (compiled from source) on an Ubuntu 11.10machine, but I
tried with GRASS64 (compiled too) and the result is the same.
I made an attempt with the NC spm dataset: I took the
elevation at PERMANENTmap and the streams at PERMANENT(vector), I copied the
streams in user1 mapset, set DEBUG at "2" and
obtained:
GRASS 6.5.svn (nc_spm_08):~ > v.rast.stats vector=streams at user1 layer=1
raster=elevation at PERMANENT colprefix=stats percentile=90 --verbose
D2/2: filename = /usr/local/grass-6.5.svn/scripts/v.rast.stats
D2/2: set GIS_FLAG_C=0
D2/2: set GIS_FLAG_E=0
D2/2: set GIS_OPT_VECTOR=streams at user1
D2/2: set GIS_OPT_LAYER=1
D2/2: set GIS_OPT_RASTER=elevation at PERMANENT
D2/2: set GIS_OPT_COLPREFIX=stats
D2/2: set GIS_OPT_PERCENTILE=90
D2/2: G__read_Cell_head
D2/2: G__read_Cell_head_array
D1/2: Vect_open_old(): name = streams at user1 mapset= user1 update = 0
D1/2: Vect_set_thresh(): thresh = 0.000000
D1/2: dig_spidx_init()
D1/2: open format file: 'user1/vector/streams/frmt'
D1/2: Vector format: 0 (native)
D1/2: Vect__read_head(): vector = streams at user1
D1/2: Level request = 2
D1/2: Vect_open_topo(): name = streams mapset= user1
D1/2: get coor info:
/home/annalisa/DATAGRASS/nc_spm_08/user1/vector/streams/coor
D1/2: Info->size = 2747992, Info->mtime = 1323518807
D2/2: Topo header: file version 5.0 , supported from GRASS version 5.0
D2/2:   byte order 0
D2/2:   header size 142
D2/2:   with_z 0
D2/2:   coor size 2747992
D1/2: Topo head: coor size = 2747992, coor mtime = 140732276991781
D1/2: dig_load_plus()
D2/2:   byte order 0
D2/2:   with_z 0
D2/2: Vect_cidx_open(): name = streams mapset= user1
D1/2: V1_open_old_nat(): name = streams mapset = user1
D2/2: Coor header: file version 5.1 , supported from GRASS version 5.1
D2/2:   byte order 0
D2/2:   with_z 0
D1/2: coor size in head = 2747992, real coor file size= 2747992
D2/2: dig_file_load ()
D2/2:   requested mode = 2
D2/2:   size = 2747992
D2/2:   file was not loaded to the memory
D1/2: Vect_open_old(): vector opened on level 2
D1/2: Vect_read_dblinks(): map = streams, mapset = user1
D1/2: dbln file:
/home/annalisa/DATAGRASS/nc_spm_08/user1/vector/streams/dbln
D1/2: dbln: 1 streams cat $GISDBASE/$LOCATION_NAME/$MAPSET/dbf/ dbf
D1/2: field = 1 name = (null), table = streams, key = cat, database =
$GISDBASE/$LOCATION_NAME/$MAPSET/dbf/, driver = dbf
D1/2: Dblinks read
D1/2: Vect_Rewind(): name = streams
D1/2: 0 areas sorted
D1/2: Vect_close(): name = streams, mapset = user1, format = 0, level = 2
D1/2: close history file
D1/2: V1_close_nat(): name = streams mapset= user1
D1/2: close streams_3353.0 compressed
ERROR: No categories found in raster map
(sorry for long email)
hope it helpes..
Thanks, Annalisa
2011/12/9 Markus Neteler <neteler at osgeo.org>
> Hi Annalisa,
> On Fri, Dec 9, 2011 at 6:22 PM, Annalisa Minelli <annagrass6 at gmail.com>
> wrote:
> > Hi all,
> > I'm experiencing some problems with v.rast.stats and (I suppose)
> v.category.
> > I have a lines vector file and I want to obtain some statistics on each
> > feature.
> > I try to use the module but it soon exits with the message:
> > v.rast.stats vector=ord1_pl_3d_cat raster=dem colprefix=stats
> percentile=90
> > --verbose -c
> > evenif I have some feature (with categories and "cat" column too on
> > associated dbf) in my file.
> could you please tell us
> - which operating system
> - which GRASS version
> > Then I tried r.category by itself and I discovered that sometimes it
> works
> > but sometimes not.
> > Align region on input raster map doesn't affect the result.
> > Any hint?
> If possible, please send a North Carolina data set example for easy
> replication.
> cheers
> Markus
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111210/d1c740d4/attachment.html
