[GRASS-user] How to find the second largest value in a series of
rasters.
Glynn Clements
glynn at gclements.plus.com
Sun Dec 11 13:34:01 EST 2011
Sylvain Maillard wrote:
> what about computing the first largest value, making your categorical map,
> and using it as a mask ?
> if you mask all cell containing the first largest value, then the second
> largest value will become the first largest value of the masked raster
> serie ...
Every cell has a largest value (provided that the cell is non-null in
at least one input map).
The problem can be solved by running "r.series method=max_raster",
then filtering each input map, setting a cell to null if the input
map has the largest value for that particular cell, then running
"r.series method=max" on the filtered maps.
But that's very inefficient compared to implementing a
"second-largest" aggregate directly.
