[GRASS-user] Is it possible to have two values for a raster. like
say value1 , value2.
Hamish
hamish_b at yahoo.com
Tue Dec 13 03:10:41 EST 2011
Pankaj wrote:
> By the way, I have troubles with v.label module. I want to show both
> the individual basin area and cumulative basin area on the map.
> But, it's not working. (No <> map error.)
we need to see the full command line you tried, and the exact output from
it. (cut and paste is best)
did you use type=centroid to select areas?
(the centroid holds the area's attribute info)
Hamish
