[GRASS-user] Re: g.extension error svn!
Solimyr giannicristian at msn.com
Tue Dec 13 04:23:11 EST 2011
Thank you very much. It was interesting but that suppose that the module it
is working (installed) in GRASS. When it is installed I can link the module
using the link that you have inserted in your post!
My problem is that I'm not able to install a new module in GRASS...I think
it's a very easy steps but I'm not able to do that....I feel so
embarassing...I have made some research but didn't found anything can help!
At the moment I have understood, thanks to the previous post, that I can't
use g.extension in Windows!
hamish-2 wrote
> Solimyr wrote:
>> Furthermore, once that I've installed in GRASS (I hope) can
>> I use in QuantumGIS using the GRASS plugin?
> see:
> http://hub.qgis.org/projects/quantum-gis/wiki/Adding_New_Tools_to_the_GRASS_Toolbox
> in the v.surf.icw addon dir there is an old example, it might need
> updating, I'm not sure.
> Hamish
> grass-user mailing list
> grass-user at .osgeo
> http://lists.osgeo.org/mailman/listinfo/grass-user
View this message in context: http://osgeo-org.1803224.n2.nabble.com/g-extension-error-svn-tp7086731p7089258.html
Sent from the Grass - Users mailing list archive at Nabble.com.
