[GRASS-user] Problems with grass for OSX
José Carlos Guerrero Antúnez
jcgantunez at gmail.com
Wed Dec 14 09:14:58 EST 2011
Hello again,
When I make double-click to open GRASS in the first terminal window show
the following message,
'/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
Last login: Wed Dec 14 08:45:59 on console
torre-b-024:~ joseca_IMac$
Rebuilding Addon HTML manual pages index...
Rebuilding Addon menu...
Python 2.6.1 found.
WELCOME TO GRASS Version 6.4.1 2011
1) Have at your side all available GRASS tutorials
2) When working on your location, the following materials
are extremely useful:
- A topo map of your area
- Current catalog of available computer maps
3) Check the GRASS webpages for feedback mailinglists and more:
http://www.grass-gis.org
http://grass.osgeo.org
Hit RETURN to continue
When I make RETURN, the message is "GRASS needs a directory in which to
store its data. Create one now if you have not already done so. A popular
choice is "grassdata", located in your home directory."
I do OK, and Choose a folder and then occurs as I mentioned in the previous
mail.
This problem as I have working with an Imac10,1, Intel Core Duo, 3,06 GHz,
RAM Memory 4 Gb. These The strangest thing for me I can do the program on
another machine (MacBook Pro, ODX 10.6.8)
I did the installation and updated according to the procedure from
Kyngchaos webpage. I have no doubt that there is some component that is in
conflict but which?
Now, what can I do?
Many thanks for your help
2011/12/10 Ralf Schäfer <senator at ecotoxicology.de>
> Dear Jose,
> when did your problem occur? After installation/updating or haphazardly?
> I had a similar problem with the Python GUI but after I updated all
> frameworks it worked fine. In case you use the GRASS version from Kyngchaos
> can you update the GDAL complete framework, free type and cairo and report
> whether the error still occurs?
> Regards
> Ralf
> Am 10.12.2011 um 05:20 schrieb grass-user-request at lists.osgeo.org:
> Message: 3
> Date: Fri, 9 Dec 2011 17:04:12 -0200
> From: Jos? Carlos Guerrero Ant?nez <jcgantunez at gmail.com>
> Subject: [GRASS-user] Problems with grass for OSX
> To: grass-user at lists.osgeo.org
> Message-ID:
> <CAEO28jeO+PyOtLMWNn8bGnY3S6c-zAxWRwL2L97Y4iryJUMY0A at mail.gmail.com>
> Content-Type: text/plain; charset="iso-8859-1"
> Hi,
> I can not boot properly grass and this is the message that appears in
> Terminal
> window.
> OSX 10.6.8
> Thanks in advance,
> Python 2.6.1 found.
> Starting GRASS ...
> Traceback (most recent call last):
> File
> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py", line
> 641, in OnSelectLocation
> self.listOfLocations[self.lblocations.GetSelection()]))
> File
> 590, in UpdateMapsets
> self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase, location)
> File
> "/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-darwin10.7.0/etc/wxpython/gui_modules/utils.py",
> line 629, in GetListOfMapsets
> File
> line 651, in EncodeString
> File
> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
> line 459, in getdefaultlocale
> return _parse_localename(localename)
> File
> line 391, in _parse_localename
> raise ValueError, 'unknown locale: %s' % localename
> ValueError: unknown locale: UTF-8
> File
> 858, in <module>
> GRASSStartUp = StartUp(0)
> File
> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> line 7981, in __init__
> File
> line 7555, in _BootstrapApp
> File
> 843, in OnInit
> StartUp.OnBrowse(None)
> File
> 703, in OnBrowse
> self.OnSetDatabase(event)
> File
> 692, in OnSetDatabase
> self.OnSelectLocation(None)
> File
> File
> File
> File
> File
> File
> Error in GUI startup. If necessary, please
> report this error to the GRASS developers.
> Switching to text mode now.
> Hit RETURN to continue...
> Dr. José Carlos Guerrero
> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> (LDSGAT)
> Instituto de Ecología y Ciencias Ambientales (IECA)
> Facultad de Ciencias
> Universidad de la República
> Montevideo-URUGUAY
(LDSGAT)
Montevideo-URUGUAY
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111214/0e878cd7/attachment.html
