[GRASS-user] Problems with grass for OSX
José Carlos Guerrero Antúnez jcgantunez at gmail.com
Wed Dec 14 10:00:58 EST 2011
I did the return in a new Terminal window and
env | grep LANG
env | grep LC_
LC_CTYPE=UTF-8
So how I can make the change?
Many thanks again,
Jose Guerrero
El 14 de diciembre de 2011 12:44, William Kyngesburye <woklist at kyngchaos.com
> escribió:
> Maybe your shell language isn't set right?  What do these return in a new
> Terminal window:
> env | grep LANG
> env | grep LC_
> OS X automatically sets LANG, but there are others that are checked first:
> LC_ALL and LC_CTYPE.  Python is expecting them to be in the form:
> language.encoding
> ie, the default US english is "en_US.UTF-8".
> If any of those are just the encoding (the "UTF-8" in your error), then
> maybe you added something to your ~/.bash_profile to set them?
> On Dec 14, 2011, at 8:14 AM, José Carlos Guerrero Antúnez wrote:
> > Hello again,
> > When I make double-click to open GRASS in the first terminal window show
> the following message,
> > '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
> > Last login: Wed Dec 14 08:45:59 on console
> > torre-b-024:~ joseca_IMac$
> > Rebuilding Addon HTML manual pages index...
> > Rebuilding Addon menu...
> > Python 2.6.1 found.
> > WELCOME TO GRASS              Version 6.4.1         2011
> >    1) Have at your side all available GRASS tutorials
> >    2) When working on your location, the following materials
> >       are extremely useful:
> >       - A topo map of your area
> >       - Current catalog of available computer maps
> >    3) Check the GRASS webpages for feedback mailinglists and more:
> >       http://www.grass-gis.org
> >       http://grass.osgeo.org
> > Hit RETURN to continue
> > When I make RETURN, the message is "GRASS needs a directory in which to
> store its data. Create one now if you have not already done so. A popular
> choice is "grassdata", located in your home directory."
> > I do OK, and Choose a folder and then occurs as I mentioned in the
> previous mail.
> > This problem as I have working with an Imac10,1, Intel Core Duo, 3,06
> GHz, RAM Memory 4 Gb. These The strangest thing for me I can do the program
> on another machine (MacBook Pro, ODX 10.6.8)
> > I did the installation and updated according to the procedure from
> Kyngchaos webpage. I have no doubt that there is some component that is in
> conflict but which?
> > Now, what can I do?
> > Many thanks for your help
> > 2011/12/10 Ralf Schäfer <senator at ecotoxicology.de>
> > Dear Jose,
> > when did your problem occur? After installation/updating or haphazardly?
> > I had a similar problem with the Python GUI but after I updated all
> frameworks it worked fine. In case you use the GRASS version from Kyngchaos
> can you update the GDAL complete framework, free type and cairo and report
> whether the error still occurs?
> > Regards
> > Ralf
> > Am 10.12.2011 um 05:20 schrieb grass-user-request at lists.osgeo.org:
> >> Message: 3
> >> Date: Fri, 9 Dec 2011 17:04:12 -0200
> >> From: Jos? Carlos Guerrero Ant?nez <jcgantunez at gmail.com>
> >> Subject: [GRASS-user] Problems with grass for OSX
> >> To: grass-user at lists.osgeo.org
> >> Message-ID:
> CAEO28jeO+PyOtLMWNn8bGnY3S6c-zAxWRwL2L97Y4iryJUMY0A at mail.gmail.com>
> >> Content-Type: text/plain; charset="iso-8859-1"
> >> Hi,
> >> I can not boot properly grass and this is the message that appears in
> Terminal
> >> window.
> >> OSX 10.6.8
> >> Thanks in advance,
> >> Python 2.6.1 found.
> >> Starting GRASS ...
> >> Traceback (most recent call last):
> >>  File
> >> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
> line
> >> 641, in OnSelectLocation
> >>    self.listOfLocations[self.lblocations.GetSelection()]))
> >>  File
> line
> >> 590, in UpdateMapsets
> >>    self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase, location)
> >>  File
> "/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-darwin10.7.0/etc/wxpython/gui_modules/utils.py",
> >> line 629, in GetListOfMapsets
> >>  File
> >> line 651, in EncodeString
> >>  File
> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
> >> line 459, in getdefaultlocale
> >>    return _parse_localename(localename)
> >>  File
> >> line 391, in _parse_localename
> >>    raise ValueError, 'unknown locale: %s' % localename
> >> ValueError: unknown locale: UTF-8
> >>  File
> line
> >> 858, in <module>
> >>    GRASSStartUp = StartUp(0)
> >>  File
> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> >> line 7981, in __init__
> >>  File
> >> line 7555, in _BootstrapApp
> >>  File
> line
> >> 843, in OnInit
> >>    StartUp.OnBrowse(None)
> >>  File
> line
> >> 703, in OnBrowse
> >>    self.OnSetDatabase(event)
> >>  File
> line
> >> 692, in OnSetDatabase
> >>    self.OnSelectLocation(None)
> >>  File
> line
> >>  File
> line
> >>  File
> >>  File
> >>  File
> >>  File
> >> Error in GUI startup. If necessary, please
> >> report this error to the GRASS developers.
> >> Switching to text mode now.
> >> Hit RETURN to continue...
> >> Dr. José Carlos Guerrero
> >> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del Territorio
> >> (LDSGAT)
> >> Instituto de Ecología y Ciencias Ambientales (IECA)
> >> Facultad de Ciencias
> >> Universidad de la República
> >> Montevideo-URUGUAY
> (LDSGAT)
> > Montevideo-URUGUAY
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
> William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> http://www.kyngchaos.com/
> Earth: "Mostly harmless"
> - revised entry in the HitchHiker's Guide to the Galaxy
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111214/7963a4cf/attachment-0001.html
