[GRASS-user] Problems with grass for OSX
    José Carlos Guerrero Antúnez
    jcgantunez at gmail.com
    Wed Dec 14 12:05:25 EST 2011
How to remove that setting, this is the mesage when I write in Terminal
window, I have all privileges as administrator.
~/.bash_profile
sh: /var/root/.bash_profile: No such file or directory
Thank you,
El 14 de diciembre de 2011 13:10, William Kyngesburye <woklist at kyngchaos.com
> escribió:
> You need to find out where that is set.  Most likely in your
> ~/.bash_profile.  Then remove that setting.
> And since your LANG is not set, you also need to check your Terminal
> preferences.  In Settings:Advanced for your default setting, check the
> International "Set locale environment variables on startup" option.
> On Dec 14, 2011, at 9:00 AM, José Carlos Guerrero Antúnez wrote:
> > Hi,
> > I did the return in a new Terminal window and
> > env | grep LANG
> > env | grep LC_
> > LC_CTYPE=UTF-8
> > So how I can make the change?
> > Many thanks again,
> > Jose Guerrero
> > El 14 de diciembre de 2011 12:44, William Kyngesburye <
> woklist at kyngchaos.com> escribió:
> > Maybe your shell language isn't set right?  What do these return in a
> new Terminal window:
> > env | grep LANG
> > env | grep LC_
> > OS X automatically sets LANG, but there are others that are checked
> first: LC_ALL and LC_CTYPE.  Python is expecting them to be in the form:
> > language.encoding
> > ie, the default US english is "en_US.UTF-8".
> > If any of those are just the encoding (the "UTF-8" in your error), then
> maybe you added something to your ~/.bash_profile to set them?
> > On Dec 14, 2011, at 8:14 AM, José Carlos Guerrero Antúnez wrote:
> > > Hello again,
> > > When I make double-click to open GRASS in the first terminal window
> show the following message,
> > > '/Applications/GRASS-6.4.app/Contents/MacOS/grass.sh'; exit
> > > Last login: Wed Dec 14 08:45:59 on console
> > > torre-b-024:~ joseca_IMac$
> > > Rebuilding Addon HTML manual pages index...
> > > Rebuilding Addon menu...
> > > Python 2.6.1 found.
> > > WELCOME TO GRASS              Version 6.4.1         2011
> > >    1) Have at your side all available GRASS tutorials
> > >    2) When working on your location, the following materials
> > >       are extremely useful:
> > >       - A topo map of your area
> > >       - Current catalog of available computer maps
> > >    3) Check the GRASS webpages for feedback mailinglists and more:
> > >       http://www.grass-gis.org
> > >       http://grass.osgeo.org
> > > Hit RETURN to continue
> > > When I make RETURN, the message is "GRASS needs a directory in which
> to store its data. Create one now if you have not already done so. A
> popular choice is "grassdata", located in your home directory."
> > > I do OK, and Choose a folder and then occurs as I mentioned in the
> previous mail.
> > > This problem as I have working with an Imac10,1, Intel Core Duo, 3,06
> GHz, RAM Memory 4 Gb. These The strangest thing for me I can do the program
> on another machine (MacBook Pro, ODX 10.6.8)
> > > I did the installation and updated according to the procedure from
> Kyngchaos webpage. I have no doubt that there is some component that is in
> conflict but which?
> > > Now, what can I do?
> > > Many thanks for your help
> > > 2011/12/10 Ralf Schäfer <senator at ecotoxicology.de>
> > > Dear Jose,
> > > when did your problem occur? After installation/updating or
> haphazardly?
> > > I had a similar problem with the Python GUI but after I updated all
> frameworks it worked fine. In case you use the GRASS version from Kyngchaos
> can you update the GDAL complete framework, free type and cairo and report
> whether the error still occurs?
> > > Regards
> > > Ralf
> > > Am 10.12.2011 um 05:20 schrieb grass-user-request at lists.osgeo.org:
> > >> Message: 3
> > >> Date: Fri, 9 Dec 2011 17:04:12 -0200
> > >> From: Jos? Carlos Guerrero Ant?nez <jcgantunez at gmail.com>
> > >> Subject: [GRASS-user] Problems with grass for OSX
> > >> To: grass-user at lists.osgeo.org
> > >> Message-ID:
> CAEO28jeO+PyOtLMWNn8bGnY3S6c-zAxWRwL2L97Y4iryJUMY0A at mail.gmail.com>
> > >> Content-Type: text/plain; charset="iso-8859-1"
> > >> Hi,
> > >> I can not boot properly grass and this is the message that appears in
> Terminal
> > >> window.
> > >> OSX 10.6.8
> > >> Thanks in advance,
> > >> Python 2.6.1 found.
> > >> Starting GRASS ...
> > >> Traceback (most recent call last):
> > >>  File
> > >> "/Applications/GRASS-6.4.app/Contents/MacOS/etc/wxpython/gis_set.py",
> line
> > >> 641, in OnSelectLocation
> > >>    self.listOfLocations[self.lblocations.GetSelection()]))
> > >>  File
> line
> > >> 590, in UpdateMapsets
> > >>    self.listOfMapsets = utils.GetListOfMapsets(self.gisdbase,
> location)
> > >>  File
> "/Users/Shared/src/GRASS/grass-6.4.1-snow/dist.i386-apple-darwin10.7.0/etc/wxpython/gui_modules/utils.py",
> > >> line 629, in GetListOfMapsets
> > >>  File
> > >> line 651, in EncodeString
> > >>  File
> "/System/Library/Frameworks/Python.framework/Versions/2.6/lib/python2.6/locale.py",
> > >> line 459, in getdefaultlocale
> > >>    return _parse_localename(localename)
> > >>  File
> > >> line 391, in _parse_localename
> > >>    raise ValueError, 'unknown locale: %s' % localename
> > >> ValueError: unknown locale: UTF-8
> > >>  File
> line
> > >> 858, in <module>
> > >>    GRASSStartUp = StartUp(0)
> > >>  File
> "/Users/Shared/unix/wxpython-snow/lib/python2.6/site-packages/wx-2.8-mac-unicode/wx/_core.py",
> > >> line 7981, in __init__
> > >>  File
> > >> line 7555, in _BootstrapApp
> > >>  File
> line
> > >> 843, in OnInit
> > >>    StartUp.OnBrowse(None)
> > >>  File
> line
> > >> 703, in OnBrowse
> > >>    self.OnSetDatabase(event)
> > >>  File
> line
> > >> 692, in OnSetDatabase
> > >>    self.OnSelectLocation(None)
> > >>  File
> line
> > >>  File
> line
> location)
> > >>  File
> > >>  File
> > >>  File
> > >>  File
> > >> Error in GUI startup. If necessary, please
> > >> report this error to the GRASS developers.
> > >> Switching to text mode now.
> > >> Hit RETURN to continue...
> > >> Dr. José Carlos Guerrero
> > >> Laboratorio de Desarrollo Sustentable y Gestión Ambiental del
> Territorio
> > >> (LDSGAT)
> > >> Instituto de Ecología y Ciencias Ambientales (IECA)
> > >> Facultad de Ciencias
> > >> Universidad de la República
> > >> Montevideo-URUGUAY
> Territorio (LDSGAT)
> > > Montevideo-URUGUAY
> > > _______________________________________________
> > > grass-user mailing list
> > > http://lists.osgeo.org/mailman/listinfo/grass-user
> > William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
> > http://www.kyngchaos.com/
> > Earth: "Mostly harmless"
> > - revised entry in the HitchHiker's Guide to the Galaxy
> "Mon Dieu! but they are all alike.  Cheating, murdering, lying, fighting,
> and all for things that the beasts of the jungle would not deign to possess
> - money to purchase the effeminate pleasures of weaklings.  And yet withal
> bound down by silly customs that make them slaves to their unhappy lot
> while firm in the belief that they be the lords of creation enjoying the
> only real pleasures of existence....
> - the wisdom of Tarzan
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111214/09e2fa3d/attachment.html
