[GRASS-user] v.to.rast problem
José Carlos Guerrero Antúnez jcgantunez at gmail.com
Sun Dec 18 17:44:24 EST 2011
I am working with GRASS 6.4.1(2011) on a OSX 10.6.8 (MaBookPro).
When I do the process for importing with v.to.rast,
According to different "Source of raster values":
- attr
Column parameter missing (or use value parameter))
- cat (Loading data, Reading areas, Reading features, Writing raster map...)
the process becomes eternal
- val (loading data, converted areas: 1 of 1, Converted points/lines: 0 of
0, t.to.rast complete, Reading features, Writing raster map,...)
The process becomes eternal
- z (Loading data)
Vector map <Uruguay at PERMANENT> is not 3D
- dir (Loading data, Reading features, Writing raster map, Converted areas:
0 of 1, Converted pointes/lines: 0 of 0, v.to.rast complete)
It is not created.
Vector file data are showed below:
 | Layer:           Uruguay at PERMANENT
 | Mapset:          PERMANENT
 | Database:        /Users/joseca/grass
 | Title:
 | Map scale:       1:1
 | Map format:      native
 | Name of creator: joseca
 | Organization:
 | Source date:     Sun Dec 18 19:31:15 2011
 |   Type of Map:  vector (level: 2)
 |   Number of points:       0               Number of areas:      1
 |   Number of lines:        0               Number of islands:    1
 |   Number of boundaries:   1               Number of faces:      0
 |   Number of centroids:    1               Number of kernels:    0
 |   Map is 3D:              No
 |   Number of dblinks:      1
 |         Projection: x,y
 |               N:  30:06:02.013245S    S:  34:58:40.005798S
 |               E:  53:05:42.004395W    W:  58:26:19.037476W
 |   Digitization threshold: 0
 |   Comments:
Thank you,
José Guerrero
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20111218/3ac3b0f5/attachment.html
