[GRASS-user] Re: about Analytic Hierarchy Process (AHP)
gianluca.massei agr.gianluca.massei at gmail.com
Wed Dec 21 13:15:00 EST 2011
In your  work  directory, r.mcda.ahp writes some additional information
in a file named  "log.txt". You can find eigenvetor, eigenvalue and
weigth vector. I think it's usefull.
hallo
Gianluca
Il 21/12/2011 18:47, leonidas ha scritto:
> Gianluca, the gui of the command is working now. I should prepare some data
> in order to check if the ahp code is working and returns valid results.
> Thank you again!
> View this message in context:http://osgeo-org.1803224.n2.nabble.com/about-Analytic-Hierarchy-Process-AHP-tp2671507p7116044.html
> Sent from the Grass - Users mailing list archive at Nabble.com.
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
