[GRASS-user] removing a vector deletes connected table by default?
    Shane Litherland
    litherland-farm at bigpond.com
    Fri Dec 23 18:56:53 EST 2011
Hi again,
wxGUI 6.4.2RC2 continued:
create a new vector, with default option of adding a new table.
When I then choose to delete the vector (g.remove via File > Manage maps
and volumes) I can delete the vector.
Watching the PostgreSQL database using PGAdmin3, when I create the
vector "testing" it creates a table by same name. when I delete the
vector, the table goes too. This is using default settings in g.remove.
I did not even choose the 'force remove' option.
I am fairly sure that previously (e.g. tcltk GUI), the process of
deleting a vector/raster DID NOT delete the table it was connected to by
default; one had to choose to do that (or even use a different tool to
delete the table).
I found that if I dropped a table (using v.db.connect) from a vector
prior to deleting the vector, the table was not deleted.
This seems to me a dangerous default, because the same thing caught me
out in ~RC1, where I connected a test vector to an existing table, then
when I deleted the test vector, my rather important table was taken out
with it!
Can anyone else debunk or support my experience here? I would consider
this a fairly serious 'bug' if it is repeatable and not just an artefact
of my system setup.
-shane.
