[GRASS-user] replacement for d.mon in GRASS 7.0?
Patrick_schirmer
patrick_GIS at gmx.ch
Tue Feb 1 05:11:04 EST 2011
Does someone know how translate previous display commands into GRASS70,
i.e. integrate a py-script that is called
"d.mon x1=start" (or similar) into GRASS70 doing these command:
#####start display in GRASS7.0
d.erase
ximgview map.bmp &
export GRASS_PNG_MAPPED=TRUE
This would allow to run GRASS64-scripts on GRASS70 and for those you
prefer direct output out of the script, just go on doing this as before.
I tried to do so, but didn't manage to handle the "export" command in
py. Maybe someone
of knows howto?
greetz, Patrick
>>> >>> I just started using d.mon in combination with d.rast to quickly display
>>> >>> a layer - but d.mon will be removed in 7.0. I assume there is a
>>> >>> replacement for it, which I can use in 7.0? I do not assume, that I have
>>> >>> to use GUI for display.
>> >> You can use wxpyimgview[1] to view the images.
>> >> [1] or wximgview or ximgview. ximgview is C/Xlib, wximgview is
>> >> C++/wxWidgets, wxpyimgview is Python/wxWidgets.
>> >> For this, you need:
>> >> Optionally:
>> >> export GRASS_NOTIFY='kill -USR1<pid>'
>> >> where<pid> is the PID of the {x,wx,wxpy}imgview process. This allows
>> >> you to set percent=0; the display will be redrawn whenever a display
>> >> command completes.
