[GRASS-user] problem: boundary lines double
mails-foren at gmx-topmail.de
Tue Feb 1 10:43:16 EST 2011
Hello Maris,
thanks a lot for replying.
Yes, I imported an esri shapefile. I'd tried to clean data with v.clean and with many different grass clean modules, without any success.
Any other idea how to solve this issue? Maybe there is a method to import esri shapefiles without saving double the boundary?
Steffen
-------- Original-Nachricht --------
> Datum: Thu, 27 Jan 2011 21:35:17 +0200
> Von: Maris Nartiss <maris.gis at gmail.com>
> An: mails-foren at gmx-topmail.de
> CC: grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] problem: boundary lines double
> Hello,
> looks like Your data are coming from non-topological vector storage
> (Shapefile?). Cleanness of data stored in non-topological formats
> (i.e. Shapefile) depend on data creation software abilities to produce
> cliean-look data and not are enforced by data storage, as it is in
> GRASS.
> Without seeing more information, my guess would be - You imported
> shapefile with areas into GRASS, still they had slivers and thus
> feature count has increased. Only way out is to clean data with
> v.clean and friends or by hand.
> Maris.
> http://grass.osgeo.org/grass64/manuals/html64_user/v.clean.html
> 2011/1/27, mails-foren at gmx-topmail.de <mails-foren at gmx-topmail.de>:
> > Hello,
> > if I import a shape (414 features) with v.in.ogr.qgis I get output with
> 594
> > features. I had read the problem is, that a boundary line between two
> > polygons get saved double. How can I manage to save as one boundary line
> > between two polygons?
> > Thanks a lot in advance!
> > Steffen
> > GMX DSL Doppel-Flat ab 19,99 Euro/mtl.! Jetzt mit
> > gratis Handy-Flat! http://portal.gmx.net/de/go/dsl
> > grass-user mailing list
> > http://lists.osgeo.org/mailman/listinfo/grass-user
NEU: FreePhone - kostenlos mobil telefonieren und surfen!
Jetzt informieren: http://www.gmx.net/de/go/freephone
