Le 03/02/2011 00:20, katrin eggert a écrit : > 1- Is it possible to define active region spatial resolution by > selecting an image instead of putting values? You can also use your mouse. Load your image in the Layer manager, right click on this map and select "Set computational region from selected map". Thibault.
