[GRASS-user] hotspot or heat map in GRASS
    Dylan Beaudette
    debeaudette at ucdavis.edu
    Fri Feb  4 11:43:15 EST 2011
On Friday, February 04, 2011, razmjooeis at faunalia.co.uk wrote:
> Dear all
> Does anyone have a tutorial or an example of how to create heatmaps or
> hotspots based on point density in GRASS.
> I tried to use v.kernel but not sure what some of the parameters mean?
> v.neighbor is straight forward but the output map is very coarse.
v.kernel is the way to go, however its output will depend on a couple things:
1. region settings
2. the size of the kernel (in terms of standard deviation)
3. obviously, the point density
tinker around with those, starting with the region settings (e.g. the
resolution), then tinker with the standard deviation (in map units) option.
Cheers,
Dylan
