[GRASS-user] Re: Unexplained DBI-DBMF error from v.in.ogr
Aren Cambre
aren at arencambre.com
Mon Feb 7 09:03:30 EST 2011
Thank you. This is a clean install of GRASS 6.4.0.
I hear you on the column warnings, but does that explain a missing password
error? Seems like two different errors. I did some Googling earlier and what
I found suggests the column warnings aren't a big deal.
Aren
On Mon, Feb 7, 2011 at 4:54 AM, Micha Silver <micha at arava.co.il> wrote:
> On 06/02/2011 07:35, Aren Cambre wrote:
> I think the problem may actually be with the build of GRASS GIS shipped
> with QGIS. I just installed 6.4.1 RC1 and now get a useful error.
> Could be that you came across a bug, but...
> If you're trying to import a PostGIS table into GRASS as a GRASS vector,
> then you need to note what database GRASS is using. From the error below
> your GRASS db connection ('db.connect -p') is local dbf files. In that case
> I believe that several of the column headers from the original PostGIS table
> are too long for the dbf format. That might be part of the problem... Also
> it could be that some of the data types from PostGIS aren't accepted by dbf.
> It might be best to move your whole GRASS database setup to sqlite - more
> robust and full featured.
> Aren
> On Sat, Feb 5, 2011 at 10:15 PM, Aren Cambre <aren at arencambre.com> wrote:
>> I am running *v.in.ogr* to import a PostGIS table. This table shows up
>> fine in QGIS. Here's the command:
>> *v.in.ogr -o "dsn=PG:dbname='de' host=localhost port=5432
>> user='[redacted]' password='[redacted]' sslmode=disable"
>> layer=consistent.master output=master_grassX*
>> This command was produced by QGIS's GRASS Tools.
>> The problem is that I get an error but no explanation at all. Here's the
>> output:
>> Width for column school_zone set to 255 (was not specified by OGR), some
>> strings may be truncated!
>> Width for column vehicle_color set to 255 (was not specified by OGR), some
>> Width for column offense_location set to 255 (was not specified by OGR),
>> some strings may be truncated!
>> Width for column work_zone set to 255 (was not specified by OGR), some
>> DBMI-DBF driver error:
>> Unable to create table: 'create table master_grassX (cat integer,
>> offense_street_name varchar ( 30 ), school_zone varchar ( 255 ),
>> defendant_dl varchar ( 20 ), defendant_dl_state varchar ( 2 ), vehicle_model
>> varchar ( 20 ), offense_code integer, vehicle_color varchar ( 255 ),
>> citation_id_base varchar ( 20 ), vehicle_make varchar ( 20 ), defendant_dob
>> date, speed_limit integer, source varchar ( 20 ),
>> vehicle_registration_expiration_date date, offense_crossstreet_number
>> varchar ( 10 ), defendant_sex varchar ( 1 ), citing_jurisdiction integer,
>> offense_county varchar ( 10 ), officer_id varchar ( 20 ), offense_location
>> varchar ( 255 ), defendant_zip varchar ( 9 ), vehicle_licenseplate_state
>> varchar ( 2 ), offense_street_number varchar ( 10 ), offense_timestamp
>> datetime, citation_id_stub varchar ( 20 ), offense_crossstreet_name varchar
>> ( 30 ), speed_alleged integer, vehicle_year integer, vehicle_licenseplate
>> varchar ( 10 ), work_zone varchar ( 255 ), defendant_race varchar ( 10 ))'
>> Finished with error
>> The problem is I get no details at all on the error cause. Yes, the
>> driver error really is blank.
>> I turned postgres logging to log all queries (following the recipe at
>> http://stackoverflow.com/questions/722221/how-to-log-postgres-sql-queries).
>> I analyzed the queries and didn't see anything surprising. I've attached the
>> log in case it's helpful.
>> I checked the */dbf* directory, and it has no files. I also checked the
>> *vector/master_grassX* directory and found no problems, just four files (
>> *coor*, *dbln*, *head*, *hist*) with unsurprising contents.
>> I'm new to GRASS, so I'm not sure what else to check. Is there another
>> log source? Did I discover a bug that needs to be filed?
>> Aren Cambre
> This mail was received via Mail-SeCure System.
> grass-user mailing listgrass-user at lists.osgeo.orghttp://lists.osgeo.org/mailman/listinfo/grass-user
> Micha Silverhttp://www.surfaces.co.il/
> Arava Development Co. +972-52-3665918
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110207/20dd39c0/attachment.html
