[GRASS-user] Import/conversion problem
Adam Dershowitz, Ph.D., P.E.
adershowitz at exponent.com
Fri Feb 11 14:08:02 EST 2011
I am also working on OS X. But, I am using the MrSID plugin, from William Kyngesburye. So it seems that both gdalwarp and r.in.gdal are willing to import it. But, maybe I will try to search around for the apps that you are referring to, to see if they might do a better job on the conversion.
Are you suggesting that the MrSID plugin that I have is working, but is loosing reference data along the way?
--Adam
On Feb 11, 2011, at 10:47 AM, Stuart Edwards wrote:
> MrSID files are a bit tricky. This is a proprietary format owned by LizardTech (see http://www.gdal.org/frmt_mrsid.html). That being said, they freely provide decode tools at their website (http://www.lizardtech.com/). Working on OS X, I use their Raster_DSDK in a little command line routine to convert the file to a geotiff (tifg) and then import it into GRASS with r.in.gdal. Note that the MrSID format is very efficient and boils a quad down to about 1.5 Gb. This will become 3 or 4 times greater as a tif so make sure you have plenty of room to store it and process it. I use an old version of Expressview (a LizardTech viewer that used to be available for OS X) to look at the image and determine the coordinates of the bit that I really want in order to minimize the resulting file sizes.
> AFAIK there are no open source apps that deal with MrSID directly (for those that do, you have to install your own version of the decoder first)
> Stu
> On Feb 11, 2011, at 12:23 PM, Adam Dershowitz, Ph.D., P.E. wrote:
>> I am trying to import some data in GRASS and have run into a problem. I hope someone can give me a little insight to help out.
>> I downloaded some aerial imagery from here:
>> http://www.michigan.gov/dnr/0,1607,7-153-10371_14546-30211--,00.html
>> I want to import it into a UTM zone 17 project. So I did the following:
>> gdalwarp -t_srs '+proj=utm +zone=17 +datum=WGS84' input.sid output_utm.sid
>> gdapwarp responds with an error, but then continues with the conversion:
>> ERROR 6: Failed to initialize PROJ.4 with `+proj=omerc +lat_0=0 +lonc=0 +alpha=0 +k=1 +x_0=0 +y_0=0 +ellps=GRS80 +datum=NAD83 +units=m +no_defs '.
>> lat_0 = 0 or 90 or alpha = 90
>> 0...10...20...30...40...50...60...70...80...90...100 - done.
>> If I then try to import the image, into my project, it does work, but places it WAY off from where it should be (millions of meters!). I guess I should not be surprised, since the error says that it is trying to use a lat/long of 0. But I don't understand why it is not working correctly.
>> So, clearly something is wrong with how I am doing the conversion. Am I missing a flag or something? It looks to me like gdalinfo is doing a correct read, but somehow gdalwarp is missing something on the input.
>> Any help would be greatly appreciated.
>> If I do gdalinfo on the input file, here is what I get:
>> Driver: MrSID/Multi-resolution Seamless Image Database (MrSID)
>> Files: oakgrove_sw.sid
>> oakgrove_sw.sdw
>> oakgrove_sw.sid.aux.xml
>> Size is 6415, 8061
>> Coordinate System is:
>> PROJCS["IMAGINE GeoTIFF Support
>> Copyright 1991 - 2001 by ERDAS, Inc. All Rights Reserved
>> @(#)$RCSfile: egtf.c $ $Revision: 1.7 $ $Date: 2001/09/27 14:59:29EDT $
>> Projection = Oblique Mercator (Hotine)|IMAGINE",
>> GEOGCS["NAD83",
>> DATUM["North_American_Datum_1983",
>> SPHEROID["GRS 1980",6378137,298.2572221010002,
>> AUTHORITY["EPSG","7019"]],
>> AUTHORITY["EPSG","6269"]],
>> PRIMEM["Greenwich",0],
>> UNIT["degree",0.0174532925199433],
>> AUTHORITY["EPSG","4269"]],
>> PROJECTION["Hotine_Oblique_Mercator"],
>> PARAMETER["latitude_of_center",0],
>> PARAMETER["longitude_of_center",0],
>> PARAMETER["azimuth",0],
>> PARAMETER["rectified_grid_angle",90],
>> PARAMETER["scale_factor",1],
>> PARAMETER["false_easting",0],
>> PARAMETER["false_northing",0],
>> UNIT["metre",1,
>> AUTHORITY["EPSG","9001"]]]
>> Origin = (663144.500000000000000,240035.500000000000000)
>> Pixel Size = (1.000000000000000,-1.000000000000000)
>> Metadata:
>> IMAGE__INPUT_NAME=K:\blk18\oakgrove_sw.tif
>> IMAGE__INPUT_FILE_SIZE=155199578.000000
>> GEOTIFF_NUM__1024__GTModelTypeGeoKey=1
>> GEOTIFF_CHAR__GTModelTypeGeoKey=ModelTypeProjected
>> GEOTIFF_NUM__1025__GTRasterTypeGeoKey=1
>> GEOTIFF_CHAR__GTRasterTypeGeoKey=RasterPixelIsArea
>> GEOTIFF_NUM__1026__GTCitationGeoKey=IMAGINE GeoTIFF Support
>> Projection = Oblique Mercator (Hotine)|IMAGINE GeoTIFF Support
>> Projection Name = Oblique Mercator (Hotine)
>> Units = meters
>> GeoTIFF Units = meters|
>> GEOTIFF_NUM__2048__GeographicTypeGeoKey=4269
>> GEOTIFF_CHAR__GeographicTypeGeoKey=GCS_NAD83
>> GEOTIFF_NUM__2060__GeogAzimuthUnitsGeoKey=9102
>> GEOTIFF_CHAR__GeogAzimuthUnitsGeoKey=Angular_Degree
>> GEOTIFF_NUM__3072__ProjectedCSTypeGeoKey=32767
>> GEOTIFF_CHAR__ProjectedCSTypeGeoKey=User-Defined
>> GEOTIFF_NUM__3073__PCSCitationGeoKey=IMAGINE GeoTIFF Support
>> Units = meters
>> GEOTIFF_NUM__3074__ProjectionGeoKey=32767
>> GEOTIFF_CHAR__ProjectionGeoKey=User-Defined
>> GEOTIFF_NUM__3075__ProjCoordTransGeoKey=3
>> GEOTIFF_CHAR__ProjCoordTransGeoKey=CT_ObliqueMercator
>> GEOTIFF_NUM__3076__ProjLinearUnitsGeoKey=9001
>> GEOTIFF_CHAR__ProjLinearUnitsGeoKey=Linear_Meter
>> GEOTIFF_NUM__3088__ProjCenterLongGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> GEOTIFF_NUM__3089__ProjCenterLatGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> GEOTIFF_NUM__3090__ProjCenterEastingGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> GEOTIFF_NUM__3091__ProjCenterNorthingGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> GEOTIFF_NUM__3093__ProjScaleAtCenterGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> GEOTIFF_NUM__3094__ProjAzimuthAngleGeoKey=0.999600,45.309167,2546731.496000,-4354009.816000,337.255560,-86.000000
>> IMAGE__Z_RESOLUTION=0.000000
>> GEO__ModelTypeGeoKey=1
>> GEO__ProjectedCSTypeGeoKey=32767
>> GEO__PCSCitationGeoKey=IMAGINE GeoTIFF Support
>> Units = meters
>> IMAGE__Z_ORIGIN=0.000000
>> IMAGE__COMPRESSION_VERSION=1,6,1
>> IMAGE__TARGET_COMPRESSION_RATIO=20.000000
>> IMAGE__COMPRESSION_NLEV=4
>> IMAGE__COMPRESSION_WEIGHT=4.000000
>> IMAGE__COMPRESSION_GAMMA=2.000000
>> IMAGE__COMPRESSION_BLOCK_SIZE=512
>> IMAGE__CREATION_DATE=Wed Mar 10 17:11:37 2004
>> VERSION=MG2
>> IMAGE__BITS_PER_SAMPLE=8
>> IMAGE__WIDTH=6415
>> IMAGE__HEIGHT=8061
>> IMAGE__COLOR_SCHEME=0
>> IMAGE__DATA_TYPE=0
>> IMAGE__XY_ORIGIN=663145.000000,240035.000000
>> IMAGE__X_RESOLUTION=1.000000
>> IMAGE__Y_RESOLUTION=1.000000
>> Image Structure Metadata:
>> INTERLEAVE=PIXEL
>> Corner Coordinates:
>> Upper Left ( 663144.500, 240035.500)
>> Lower Left ( 663144.500, 231974.500)
>> Upper Right ( 669559.500, 240035.500)
>> Lower Right ( 669559.500, 231974.500)
>> Center ( 666352.000, 236005.000)
>> Band 1 Block=1024x128 Type=Byte, ColorInterp=Red
>> Minimum=0.000, Maximum=255.000, Mean=97.677, StdDev=49.163
>> Overviews: 3208x4031, 1604x2016, 802x1008, 401x504
>> Band 2 Block=1024x128 Type=Byte, ColorInterp=Green
>> Minimum=0.000, Maximum=255.000, Mean=97.555, StdDev=49.371
>> Band 3 Block=1024x128 Type=Byte, ColorInterp=Blue
>> Minimum=0.000, Maximum=255.000, Mean=97.402, StdDev=49.024
>> --Adam
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
