[GRASS-user] calculating perimeter per patch
Markus Metz
markus.metz.giswork at googlemail.com
Sat Feb 12 03:41:09 EST 2011
On Sat, Feb 12, 2011 at 5:11 AM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Dear all,
> I have a raster map where each patch (i.e. forest fragment) have different
> ID.
> I need to estimate the perimeter per patch, but R.le.patch can't do the job.
Have you tried a vector approach? Then the perimeter can be simply uploaded with
v.to.db option=perimeter.
(Watch out for the fractal problem, both r.le.patch and v.to.db)
Markus M
> GRASS 6.4> r.le.patch map=fragments sam=w per=p1 siz=s1 out=STATS.txt
> PARAMETER CHOICES:
> MAP: fragments
> SAMPLE: whole map TRACING: 8 neighbor
> SIZE MEASURES:
> mean patch size
> PERIMETER MEASURES:
> sum of perims
> R.LE.PATCH IS WORKING....;
> ERROR: G_calloc: unable to allocate 24806 * 8 bytes at alloc_cell.c:83
> Any hint?
> bests
> milton
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
