[GRASS-user] calculating perimeter per patch
Markus Metz
markus.metz.giswork at googlemail.com
Sat Feb 12 06:18:11 EST 2011
On Sat, Feb 12, 2011 at 11:58 AM, Milton Cezar Ribeiro
<miltinho.astronauta at gmail.com> wrote:
> Hi Markus,
> Thanks for the reply. In fact a vector-based should solve this.
> But, unfortulatelly, as I am working with a very large raster map
> (48,000 x 60,000 pixels; 250,000 clumps), and GRASS fail when
> I try r.to.vect under Windows/Vista. Is there any other options
> of convert large raster maps to vector, instead of r.to.vect?
No, but you could try a recent version of GRASS 7 and after starting
GRASS, set at the commandline
export GRASS_VECTOR_LOWMEM=1
then try r.to.vect
It will take some time, but it should finish eventually.
Markus M
> Markus Metz:
>> Milton Cezar Ribeiro:
>> > Dear all,
>> > I have a raster map where each patch (i.e. forest fragment) have
>> > different
>> > ID.
>> > I need to estimate the perimeter per patch, but R.le.patch can't do the
>> > job.
>> Have you tried a vector approach? Then the perimeter can be simply
>> uploaded with
>> v.to.db option=perimeter.
>> (Watch out for the fractal problem, both r.le.patch and v.to.db)
>> Markus M
>> > GRASS 6.4> r.le.patch map=fragments sam=w per=p1 siz=s1 out=STATS.txt
>> > PARAMETER CHOICES:
>> > MAP: fragments
>> > SAMPLE: whole map TRACING: 8 neighbor
>> > SIZE MEASURES:
>> > mean patch size
>> > PERIMETER MEASURES:
>> > sum of perims
>> > R.LE.PATCH IS WORKING....;
>> > ERROR: G_calloc: unable to allocate 24806 * 8 bytes at alloc_cell.c:83
>> > Any hint?
>> > bests
>> > milton
>> > _______________________________________________
>> > grass-user mailing list
>> > grass-user at lists.osgeo.org
>> > http://lists.osgeo.org/mailman/listinfo/grass-user
