[GRASS-user] Re: Compiling GRASS 7.0 on Mac OSX 10.6.6
Johannes Radinger
JRadinger at gmx.at
Thu Feb 24 10:10:22 EST 2011
-------- Original-Nachricht --------
> Datum: Thu, 24 Feb 2011 15:48:33 +0100
> Von: Markus Neteler <neteler at osgeo.org>
> An: Johannes Radinger <JRadinger at gmx.at>
> CC: William Kyngesburye <kyngchaos at kyngchaos.com>, grass-user at lists.osgeo.org
> Betreff: Re: [GRASS-user] Re: Compiling GRASS 7.0 on Mac OSX 10.6.6
> On Thu, Feb 24, 2011 at 12:28 PM, Johannes Radinger <JRadinger at gmx.at>
> wrote:
> > Errors in:
> /Users/admin/Downloads/grass-7.0.svn_src_snapshot_2011_02_19/visualization/nviz
> > Finished compilation: Do 24 Feb 2011 12:18:01 CET
> > make: *** [default] Error 1
> > So I changed to the nviz directory and ran again make and there I get:
> > make -C src
> > gcc -g -O2
> -I/users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_19/dist.i386-apple-darwin10.6.0/include
> -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/Tcl.framework/Headers
> -I/Library/Frameworks/Tk.framework/Headers
> -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/Tcl.framework/Headers
> -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders
> -I/Library/Frameworks/UnixImageIO.framework/unix/include
> -I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers
> -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include -DPACKAGE=\""grassmods"\"
> -I/users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_19/dist.i386-apple-darwin10.6.0/include -o
> OBJ.i386-apple-darwin10.6.0/togl.o -c togl.c
> > In file included from togl.c:53:
> > /Library/Frameworks/Tk.framework/Headers/tkMacOSX.h:31: error: expected
> declaration specifiers or ‘...’ before ‘TkRegion’
> > togl.c: In function ‘SetMacBufRect’:
> > togl.c:1088: error: ‘struct TkWindowPrivate’ has no member named
> ‘grafPtr’
> > togl.c: In function ‘Togl_CreateWindow’:
> > togl.c:2221: warning: cast to pointer from integer of different size
> > togl.c:2338: warning: ‘aglSetDrawable’ is deprecated (declared at
> /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
> > togl.c:2340: error: ‘struct TkWindowPrivate’ has no member named
> ‘grafPtr’
> > togl.c: In function ‘Togl_EventProc’:
> > togl.c:2594: warning: ‘AGLDrawable’ is deprecated
> > togl.c:2596: warning: ‘aglSetDrawable’ is deprecated (declared at
> > togl.c:2610: warning: ‘aglSetDrawable’ is deprecated (declared at
> > togl.c: In function ‘Togl_LoadBitmapFont’:
> > togl.c:3143: warning: ‘aglUseFont’ is deprecated (declared at
> /System/Library/Frameworks/AGL.framework/Headers/agl.h:374)
> > make[1]: *** [OBJ.i386-apple-darwin10.6.0/togl.o] Error 1
> > make: *** [default] Error 2
> In visualization/nviz/src/togl.c there are some conditions:
> #if TK_MAJOR_VERSION < 8
> # error Sorry Togl requires Tcl/Tk ver 8.0 or higher.
> #endif
> #if defined(TOGL_AGL_CLASSIC)
> # if TK_MAJOR_VERSION < 8 || (TK_MAJOR_VERSION == 8 && TK_MINOR_VERSION <
> 3)
> # error Sorry Mac classic version requires Tcl/Tk ver 8.3.0 or higher.
> # endif
> #endif /* TOGL_AGL_CLASSIC */
> #if defined(TOGL_AGL)
> 4)
> # error Sorry Mac Aqua version requires Tcl/Tk ver 8.4.0 or higher.
> # endif
> #endif /* TOGL_AGL */
> Maybe helpful?
Not yet, do you think that has something to do with my TCL/TK libraries?
I got it via installer from http://www.activestate.com/activetcl/downloads
Thats the version of ActiveTCL 8.5.9.2...Is there the TK included?
Do I have to get TCL/TK directly compiled from the source code for GRASS?
Johannes
> Markus
Schon gehört? GMX hat einen genialen Phishing-Filter in die
Toolbar eingebaut! http://www.gmx.net/de/go/toolbar
