[GRASS-user] How to merge rasters using feathering/blending ?
Hamish
hamish_b at yahoo.com
Thu Feb 24 18:10:32 EST 2011
kaipi wrote:
> I need to patch rasters containing NULL areas with
> alternative rasters. I can
> do this with r.patch but due to different
> quality/resolution of the rasters
> this produces prominent seamlines. Is there a way to
> feather/blend between
> merged rasters using Grass GIS?
for blending try:
g.region rast=map1,map2
r.series in=map1,map2 out=both_maps method=average
where there are two values it will take the average
where there is just one value it will use that
where there are NULLs or outside-of-map you'll get a NULL.
Hamish
