[GRASS-user] Re: Compiling GRASS 7.0 on Mac OSX 10.6.6
William Kyngesburye woklist at kyngchaos.com
Fri Feb 25 09:36:42 EST 2011
I don't think Maris meant you can't use TclTk 8.5, but > 8.5, or 8.6+.  8.6 is known to have problems.  I haven't built GRASS 7 in a while, but TclTk 8.5 works fine for GRASS 6.x, and is recommended for OS X.
I don't know if anything has been changed in GRASS 7.
On Feb 25, 2011, at 7:42 AM, Johannes Radinger wrote:
> -------- Original-Nachricht --------
>> Datum: Thu, 24 Feb 2011 15:48:33 +0100
>> Von: Markus Neteler <neteler at osgeo.org>
>> An: Johannes Radinger <JRadinger at gmx.at>
>> CC: William Kyngesburye <kyngchaos at kyngchaos.com>, grass-user at lists.osgeo.org
>> Betreff: Re: [GRASS-user] Re: Compiling GRASS 7.0 on Mac OSX 10.6.6
>> On Thu, Feb 24, 2011 at 12:28 PM, Johannes Radinger <JRadinger at gmx.at>
>> wrote:
>>> Errors in:
>> /Users/admin/Downloads/grass-7.0.svn_src_snapshot_2011_02_19/visualization/nviz
>>> Finished compilation: Do 24 Feb 2011 12:18:01 CET
>>> make: *** [default] Error 1
>>> So I changed to the nviz directory and ran again make and there I get:
>>> make -C src
>>> gcc  -g -O2
>> -I/users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_19/dist.i386-apple-darwin10.6.0/include
>>  -D_FILE_OFFSET_BITS=64 -I/Library/Frameworks/Tcl.framework/Headers
>> -I/Library/Frameworks/Tk.framework/Headers
>> -I/Library/Frameworks/Tk.framework/PrivateHeaders -I/Library/Frameworks/Tcl.framework/Headers
>> -I/Library/Frameworks/Tk.framework/Headers -I/Library/Frameworks/Tk.framework/PrivateHeaders
>> -I/Library/Frameworks/UnixImageIO.framework/unix/include
>>  -I/Library/Frameworks/GDAL.framework/Versions/1.8/Headers
>> -I/Library/Frameworks/GEOS.framework/Versions/3/unix/include  -DPACKAGE=\""grassmods"\"
>> -I/users/admin/downloads/grass-7.0.svn_src_snapshot_2011_02_19/dist.i386-apple-darwin10.6.0/include -o
>> OBJ.i386-apple-darwin10.6.0/togl.o -c togl.c
>>> In file included from togl.c:53:
>>> /Library/Frameworks/Tk.framework/Headers/tkMacOSX.h:31: error: expected
>> declaration specifiers or ‘...’ before ‘TkRegion’
>>> togl.c: In function ‘SetMacBufRect’:
>>> togl.c:1088: error: ‘struct TkWindowPrivate’ has no member named
>> ‘grafPtr’
>>> togl.c: In function ‘Togl_CreateWindow’:
>>> togl.c:2221: warning: cast to pointer from integer of different size
>>> togl.c:2338: warning: ‘aglSetDrawable’ is deprecated (declared at
>> /System/Library/Frameworks/AGL.framework/Headers/agl.h:313)
>>> togl.c:2340: error: ‘struct TkWindowPrivate’ has no member named
>> ‘grafPtr’
>>> togl.c: In function ‘Togl_EventProc’:
>>> togl.c:2594: warning: ‘AGLDrawable’ is deprecated
>>> togl.c:2596: warning: ‘aglSetDrawable’ is deprecated (declared at
>>> togl.c:2610: warning: ‘aglSetDrawable’ is deprecated (declared at
>>> togl.c: In function ‘Togl_LoadBitmapFont’:
>>> togl.c:3143: warning: ‘aglUseFont’ is deprecated (declared at
>> /System/Library/Frameworks/AGL.framework/Headers/agl.h:374)
>>> make[1]: *** [OBJ.i386-apple-darwin10.6.0/togl.o] Error 1
>>> make: *** [default] Error 2
>> In visualization/nviz/src/togl.c there are some conditions:
>> #if TK_MAJOR_VERSION < 8
>> #  error Sorry Togl requires Tcl/Tk ver 8.0 or higher.
>> #endif
>> #if defined(TOGL_AGL_CLASSIC)
>> #  if TK_MAJOR_VERSION < 8 || (TK_MAJOR_VERSION == 8 && TK_MINOR_VERSION <
>> 3)
>> #    error Sorry Mac classic version requires Tcl/Tk ver 8.3.0 or higher.
>> #  endif
>> #endif /* TOGL_AGL_CLASSIC */
>> #if defined(TOGL_AGL)
>> 4)
>> #    error Sorry Mac Aqua version requires Tcl/Tk ver 8.4.0 or higher.
>> #  endif
>> #endif /* TOGL_AGL */
>> Maybe helpful?
>> Markus
> Does anyone know what to do? How are the Mac users get their compilation working with this Mac-Tcl/Tk-NVIZ issue?
> Would it be useful to install an older version of ActiveTcl (e.g 8.4.x) over my 8.5.9 version ?
> thanks
> Johannes
> Schon gehört? GMX hat einen genialen Phishing-Filter in die
> Toolbar eingebaut! http://www.gmx.net/de/go/toolbar
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
William Kyngesburye <kyngchaos*at*kyngchaos*dot*com>
http://www.kyngchaos.com/
All generalizations are dangerous, even this one.
