[GRASS-user] Re: How to merge rasters using feathering/blending ?
Saber Razmjooei
razmjooeis at faunalia.co.uk
Mon Feb 28 07:20:53 EST 2011
If you are working with Images, maybe try to use GIMP. It has stitching
and smoothing/blending options. I use them quite often for my photos.
Regards
Sab
On Mon, 2011-02-28 at 04:05 -0800, kaipi wrote:
> > You can create a buffer zone between your 2 dataset where they merge and
> > set the buffer to null values. Then using r.fillnulls
> Thanks. This works fine for elevation data but not for satellite imagery.
> > g.region rast=map1,map2
> > r.series in=map1,map2 out=both_maps method=average
> Thanks. But this is not really a smooth blending/fading/feathering ? Any
> alternatives ?
> Kaipi
