[GRASS-user] calculating average value over a base map
Christian Schwartze christian.schwartze at uni-jena.de
Mon Feb 28 10:55:48 EST 2011
Monica,
try to use r.statistics with the average function/method. Pass you maps through the cover= and base= parameters...
Christian.
Sent: Monday, February 28, 2011 4:27 PM
To: GRASS user list
Subject: [GRASS-user] calculating average value over a base map
Greetings
I have a map with values and a base map created with r.clump. How can I calculate the average of values that falls inside each cluster defined by r.clump?
Thanks
Best regards,
Monica
grass-user mailing list
grass-user at lists.osgeo.org
http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110228/90b09b51/attachment.html
