[GRASS-user] List files and count
Glynn Clements
glynn at gclements.plus.com
Mon Jan 10 11:03:35 EST 2011
António Rocha wrote:
> I need to find, in a certain mapset, a list of files with a name that
> match a certain string and count them. How can I do this? I'm
> implementing this in a Py Script
grass.script.mlist() provides an interface to g.mlist, although it
only supports glob patterns and not regexps. If you need regexps:
def mlist(type, pattern = None, mapset = None):
result = list()
for line in read_command("g.mlist",
flags = 'r',
type = type,
pattern = pattern,
mapset = mapset).splitlines():
result.append(line.strip())
return result
