[GRASS-user] Using Access .mdb Files
Rich Shepard
rshepard at appl-ecosys.com
Tue Jan 11 16:54:53 EST 2011
On Tue, 11 Jan 2011, John C. Tull wrote:
> Did it preserve spatial topology for you? I was able to successfully
> convert an mdb to sqlite, but it does not have any geographic reference.
> This is fine for extracting data tables, but seems to sacrifice the value
> of a spatial database, unless there are fields representing coordinates
> for each table row.
John,
I've no idea. I'm only unzipping BLM data files now. I assume that Access
has no topology as it's a flatfile database that could be used as a front
end to SQL-Server.
The file I have is for land status (i.e., ownership) and the SQLite tables
are:
sqlite> .tab
GDB_AnnoSymbols GDB_GeomColumns GDB_ReplicasEx
GDB_AttrRules GDB_JnConnRules GDB_SpatialRefs
GDB_CodedDomains GDB_ObjectClasses GDB_Subtypes
GDB_DefaultValues GDB_RangeDomains GDB_Toolboxes
GDB_Domains GDB_RasterCatalogs GDB_TopoClasses
GDB_EdgeConnRules GDB_RelClasses GDB_TopoRules
GDB_ExtensionDatasets GDB_RelRules GDB_Topologies
GDB_Extensions GDB_ReleaseInfo GDB_UserMetadata
GDB_FeatureClasses GDB_ReplicaDatasets GDB_ValidRules
GDB_FeatureDataset GDB_ReplicaLog Ownership
GDB_FieldInfo GDB_Replicas Ownership_Shape_Index
I've no idea what the GDB_ prefix is supposed to mean. The Bureau
apparently does not have these data on their ESRI GIS or we'd see .shp or
.e00 files rather than .mdb files.
Rich
