[GRASS-user] Re: r.mapcalc --> 3 maps
Maciej Sieczka msieczka at sieczka.org
Sun Jan 16 15:49:44 EST 2011
W dniu 16.01.2011 18:29, Gabriele N. pisze:
> A and B do not overlap, and I should take the values of A and B also
> (always). Then.....in areas that are empty, I would then put the values of
> C.
> I tried with    r.mapcalc "output = if((isnull(a)),b,if(isnull(b),a),c)"
> but I lose the values of C
This should work:
r.mapcalc 'd=if(isnull(a),if(isnull(b),c,b),a)'
If map a is null check if b is null too. If so, use c; if not - use b.
Otherwise use a.
Or:
r.mapcalc 'd=if(isnull(a|||b),c,if(isnull(a),b,a))'
If both a and b are null, use c; if a is null use b, otherwise use a.
Maciek
Maciej Sieczka
http://www.sieczka.org
