[GRASS-user] [more] issues with python scripts
Glynn Clements
glynn at gclements.plus.com
Mon Jan 17 12:08:30 EST 2011
Carlos Grohmann wrote:
> just to add to the last email:
> grray() isnot working.
> this is what I get, with any raster:
> >>> a = garray.array()
> >>> a
> array([[ 0., 0., 0., ..., 0., 0., 0.],
> [ 0., 0., 0., ..., 0., 0., 0.]])
> >>> a.read("elevation.dem")
> Sorry, <f> is not a valid flag
> Sorry, <bytes> is not a valid parameter
This suggests that you're using 6.x.
The grass.array module won't work with 6.x, as it requires changes to
r.in.bin and r.out.bin which are only present in 7.0. It was
back-ported to 6.x by mistake, and should probably be removed.
