[GRASS-user] Re: r.out.xyz problem floating point
Clémentine Fritsch clementine.fritsch at univ-fcomte.fr
Mon Jan 24 05:56:48 EST 2011
I have not found any solution in GRASS, but it is possible to export a
xyz text file from an ASCII using R.
I have found a solution with the help of Robert Hijmans and Patrick
Giraudoux. It is necessary to specify the number of significant digits
using signif().
For instance, in R 2.12.0:
library(raster)
r<-raster("data.asc")
xyv <- cbind(xyFromCell(r, 1:ncell(r)), v=signif(values(r), digits=2))
write.table(xyv, file="data.txt", row.names=FALSE, sep="\t",dec=".")
Regards,
Clémentine
Clémentine Fritsch a écrit :
> I need to export a x,y,z text file from an ascii file.
> I have run r.out.xyz in GRASS 6.4.0 but the values of z in the output
> file are incorrect. To check, I have tried to export using r.out.ascii
> with the parameter “dp=2” and in this case, the values are correct.
> Therefore, I suppose that the problem is due to floating point.
> I have unsuccessfully tried to specify the number of significant
> digits in r.out.xyz using “dp” parameter.
> Is it possible to specify the number of significant digits in r.out.xyz?
> If not, how could I export a x,y,z text file from my ascii?
> Thanks for your help,
> Clémentine
Clémentine Fritsch
PhD, post-doc researcher
UMR 6249 - Chrono-Environment
University of Franche-Comte
Place Leclerc
F-25030 Besançon Cedex
FRANCE
E-mail: clementine.fritsch at univ-fcomte.fr
Tel.: +33 (0) 381 665 710
Fax: +33 (0) 381 665 797
Type: text/x-vcard
Desc: not available
Url : http://lists.osgeo.org/pipermail/grass-user/attachments/20110124/d96878e3/clementine_fritsch.vcf
