[GRASS-user] replacement for d.mon in GRASS 7.0?
Michael Barton Michael.Barton at asu.edu
Mon Jan 31 10:59:30 EST 2011
Also note that GRASS 6 and 7 now has a command console embedded in the interface. You can type d.rast there and the map will display in the display canvas. The command console also has autocompletion and command hints (type tab after a command).
Michael
____________________
C. Michael Barton
Director, Center for Social Dynamics & Complexity
Professor of Anthropology, School of Human Evolution & Social Change
Arizona State University
voice: 	480-965-6262 (SHESC), 480-727-9746 (CSDC)
fax:          480-965-7671 (SHESC),  480-727-0709 (CSDC)
www: http://www.public.asu.edu/~cmbarton, http://csdc.asu.edu
On Jan 31, 2011, at 2:16 AM, <grass-user-request at lists.osgeo.org> wrote:
> Message: 7
> Date: Mon, 31 Jan 2011 10:15:27 +0100
> From: Rainer M Krug <r.m.krug at gmail.com>
> Subject: Re: [GRASS-user] replacement for d.mon in GRASS 7.0?
> To: Glynn Clements <glynn at gclements.plus.com>
> Cc: grass mailing list <grass-user at lists.osgeo.org>
> Message-ID: <4D467DAF.30608 at gmail.com>
> Content-Type: text/plain; charset=ISO-8859-1
> -----BEGIN PGP SIGNED MESSAGE-----
> Hash: SHA1
> On 01/29/2011 06:36 AM, Glynn Clements wrote:
>> Rainer M Krug wrote:
>>> I just started using d.mon in combination with d.rast to quickly display
>>> a layer - but d.mon will be removed in 7.0. I assume there is a
>>> replacement for it, which I can use in 7.0? I do not assume, that I have
>>> to use GUI for display.
>> You can use wxpyimgview[1] to view the images.
>> [1] or wximgview or ximgview. ximgview is C/Xlib, wximgview is
>> C++/wxWidgets, wxpyimgview is Python/wxWidgets.
>> For this, you need:
>>      export GRASS_PNG_MAPPED=TRUE
>> Optionally:
>>      export GRASS_NOTIFY='kill -USR1 <pid>'
>> where <pid> is the PID of the {x,wx,wxpy}imgview process. This allows
>> you to set percent=0; the display will be redrawn whenever a display
>> command completes.
> Thanks - looks interesting. I'll look into that.
> As I am doing quite straight forward GIS stuff, I might try 7.0 and see
> how it goes.
> Thanks,
> Rainer
