[GRASS-user] Exporting labels of a raster
Rainer M Krug
r.m.krug at gmail.com
Fri Jul 1 09:31:12 EDT 2011
On Fri, Jul 1, 2011 at 3:24 PM, Luisa Peña <luisapena1979 at gmail.com> wrote:
> And export it as a raster map? I mean raster with an associated legend? Not
> possible?
No idea - somebody else has to help here about export formats which support
labels.
Rainer
> 2011/7/1 Rainer M Krug <r.m.krug at gmail.com>
>> On Fri, Jul 1, 2011 at 3:18 PM, Luisa Peña <luisapena1979 at gmail.com>wrote:
>>> Hi Rainer (back to ML)
>>> I have a classification procedure that produces land-use/cover maps with
>>> numerical classes between 1 and 5.
>>>> Ok - that seems to be fine.
>>>>> Then I want to produce another map, but with text labels for each
>>>>> class.
>>>> You have done this with r.reclass
>>> That's right. When I select a pixel I get something like this |
>>> coordinateX | CoordinateY ||1 | URban|
>>>>> And be able to export this raster with its labels.
>>>> As a map?
>>>> Because in grass, you can not create a raster with non-numeric values,
>>>> unless they are labels, and the cell values are numeric. If you want to have
>>>> the labels in a legend, that is a different issue. I do not know if any
>>>> export format supports the export of labels as well.
>>> Uhm. If this is not possible, how can I export a raster map with labels
>>> in a legend?
>> Check the ps.map command in grass to create maps - you will be able to
>> create a map with legend using the labels and export it as postsript file.
>> Rianer
>>> Thank you so much
>> Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation
>> Biology, UCT), Dipl. Phys. (Germany)
>> Centre of Excellence for Invasion Biology
>> Stellenbosch University
>> South Africa
>> Tel : +33 - (0)9 53 10 27 44
>> Cell: +33 - (0)6 85 62 59 98
>> Fax (F): +33 - (0)9 58 10 27 44
>> Fax (D): +49 - (0)3 21 21 25 22 44
>> email: Rainer at krugs.de
>> Skype: RMkrug
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
South Africa
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110701/823278aa/attachment.html
