[GRASS-user] Re: r.water.outlet and longitude / window issue
Andy Wickert
wickert at colorado.edu
Sat Jul 2 14:33:17 EDT 2011
OK - great!
Didn't mean the the "knows/cares" in a bad way - more a matter of fact one
:). I figured that when I didn't get a response, it was because no one had a
solution off the top of their head, so I'd have to do it.
Thanks!
Andy
On Sat, Jul 2, 2011 at 12:12 PM, Daniel Lee <lee at isi-solutions.org> wrote:
> Hi Andy,
> I think it's great that you've fixed the bug. I read your emails with
> interest but, as it's not my area of expertise, I didn't write back. As far
> as changes to the GRASS source goes, I do think that the grass-dev list
> would be the right place to take up such issues. You'd have my blessing at
> least ;)
> Best,
> Daniel
> On Sat, Jul 2, 2011 at 8:10 PM, Andy Wickert <wickert at colorado.edu> wrote:
>> SOLVED:
>> Built and installed GRASS 6.4.2 from svn, and added a line as noted below;
>> inserted at line 101 in 6.4.2 (see surrounding lines for context).
>> Recompiled r.water.outlet and it works like a charm.
>> It is totally obvious that this is not an issue that anyone on this list
>> knows/cares about, so could someone at least let me know where to take it
>> such that can get incorporated into the GRASS source and no one else has the
>> same problem? I'm thinking the grass-dev list, but I'd rather not use a
>> loudspeaker to have another conversation with myself if I can avoid it :)
>> G_usage();
>> exit(EXIT_FAILURE);
>> E = G_adjust_east_longitude(E,window.west); // <-- NEW LINE; for using
>> lat/lon data that straddle the 180 meridian
>> if (E < window.west || E > window.east || N < window.south ||
>> N > window.north) {
>> Andy Wickert
>> PhD Candidate
>> University of Colorado
>> Geological Sciences & Institute of Arctic and Alpine Research
>> 1560 30th St.
>> Boulder, CO 80303
>> Office: RL3-275
>> On Sat, Jul 2, 2011 at 3:01 AM, Andy Wickert <wickert at colorado.edu>wrote:
>>> So, in short, I think that we could add the following at line 106 in
>>> main.c for r.water.outlet (see
>>> http://trac.osgeo.org/grass/browser/grass/trunk/raster/r.water.outlet/main.c
>>> if (window.east > 180 && G_projection()==3){
>>> E = E+360;
>>> Or, if I understand G_adjust_easting(), then we might be able to skip all
>>> of that and simply type:
>>> Sound like a good improvement?
>>> Andy
>>> On Sat, Jul 2, 2011 at 2:16 AM, Andy Wickert <wickert at colorado.edu>wrote:
>>>> Made some progress on this myself; think that a solution will require
>>>> some minor source code modifications.
>>>> The main idea and my question to GRASS users/developers:
>>>> I think that I better understand the r.water.outlet problem now.
>>>> Briefly, I think a proper solution would require changing the r.water.outlet
>>>> source code to deal with wraparound at the 180 meridian; as it stands, the
>>>> code seems to be designed for northing/easting in projected coordinate
>>>> systems. I'd be happy to change / recompile / test the source code; in that
>>>> case, should I take this thread to the GRASS-dev list? I have found the
>>>> programmer's manual, but if anyone has advice on how to start in on
>>>> development in GRASS, I would greatly appreciate it.
>>>> Slightly more info:
>>>> I was able to make all the points work by specifying the window as
>>>> W:-180, E:180. However, the drainage basins refused to cross the 180
>>>> meridian. I am fairly sure that these are because (1) I need increasing
>>>> Easting values to make r.water.outlet work, but (2) in order to provide
>>>> continously increasing Easting values, I must make a discontinuity at the
>>>> 180 meridian in the middle of my data set. This makes me think that if I
>>>> changed main.c inside r.water.outlet to include G_adjust_easting() within
>>>> some if statments (is lat/long projection & West value is greater than
>>>> East), that this would solve the problem.
>>>> The workaround, of course, is to shift all location references by 180
>>>> degrees, perform calculations, and move everything back, but I'd like to try
>>>> to make a more elegant/permanent solution.
>>>> Andy
>>>> On Tue, Jun 28, 2011 at 11:43 AM, Andy Wickert <wickert at colorado.edu>wrote:
>>>>> OK - I think I figured out some of it. On my computer where
>>>>> r.water.outlet DOES work, the west-longitudes are expressed as negative
>>>>> 0-180, while on the computer where it doesn't work, they are expressed as
>>>>> positive east-longitude 180-360.
>>>>> So: the question becomes, how do I choose how west-longitudes are
>>>>> interpreted by GRASS?
>>>>> Thanks!
>>>>> Andy
>>>>> On Mon, Jun 27, 2011 at 11:00 PM, Andy Wickert <wickert at colorado.edu>wrote:
>>>>>> Hi GRASS user-list,
>>>>>> I think that I have run into a bug in either the computational window
>>>>>> definition or the r.water.outlet program (or maybe something else) that has
>>>>>> to do with defining degrees West as either positive (East-longitude >180) or
>>>>>> negative.
>>>>>> What happens is that, for example, I type:
>>>>>> r.water.outlet drainage=$watershed_direction basin=temp_basin
>>>>>> easting=196 northing=60 --verbose --overwrite
>>>>>> And GRASS returns:
>>>>>> WARNING: Warning, ignoring point outside window:
>>>>>> -164.0000,60.0000
>>>>>> This occurs no matter whether I specify the longitude as a positive
>>>>>> East-longitude (as above), as a negative value (e.g.,-164), or as, e.g.,
>>>>>> 164W. (196E is not allowed).
>>>>>> The problem is not my window definition, which includes the point in
>>>>>> question:
>>>>>> proj: 3
>>>>>> zone: 0
>>>>>> north: 73:00:30N
>>>>>> south: 49:59:30N
>>>>>> east: 144:59:30W
>>>>>> west: 162:59:30E
>>>>>> cols: 3121
>>>>>> rows: 1381
>>>>>> e-w resol: 0:01
>>>>>> n-s resol: 0:01
>>>>>> top: 1
>>>>>> bottom: 0
>>>>>> cols3: 3121
>>>>>> rows3: 1381
>>>>>> depths: 1
>>>>>> e-w resol3: 0:01
>>>>>> n-s resol3: 0:01
>>>>>> t-b resol: 1
>>>>>> When I use r.what, it gives me East-longitudes (values >180) for
>>>>>> regions to the East of the 180 meridian. But r.water.outlet insists on
>>>>>> switching everything to negatives no matter what input I give it, which I
>>>>>> think is a source of the problem.
>>>>>> The strangest thing about this is that I ran into this problem while
>>>>>> following a routine that I had written several months ago in Bash; last
>>>>>> time, I ran r.water.outlet on North America (all in degrees-west land) with
>>>>>> no problems at all. I just checked the computational region (window) files
>>>>>> for that run, and they look very similar to the ones I am using now. I have
>>>>>> no clue why I didn't run into this problem back then / why it is cropping up
>>>>>> now; both computers are running GRASS 6.4.1 on Ubuntu Linux.
>>>>>> Anyway, if anyone has any suggestions, I'm all ears. Many thanks in
>>>>>> advance,
>>>>>> Andy Wickert
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
> B.Sc. Daniel Lee
> Geschäftsführung für Forschung und Entwicklung
> ISIS - International Solar Information Solutions
> Deutschhausstr. 10
> 35037 Marburg
> Festnetz: +49 6421 379 6256
> Mobil: +49 176 6127 7269
> E-Mail: Lee at isi-solutions.org
> Web: http://www.isi-solutions.org
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110702/f656772d/attachment.html
