[GRASS-user] Using r.resamp.stats for null values
Glynn Clements
glynn at gclements.plus.com
Tue Jul 5 20:34:01 EDT 2011
katrin eggert wrote:
> Just one question: is it possible to "count" number of cells with a certain
> value (or nulls) from one scale that are being used to calculate each value
> pixel of the target scale?
Not directly, but you can create a binary (0/1 or null/1) version of
the input map then use "r.resamp.stats method=sum ..." on that.
