[GRASS-user] incorrect boundaries fixed by v.out + v.in ?
Hendrik Hoeth
hoeth at linta.de
Sat Jul 16 14:41:21 EDT 2011
I have some trouble with incorrect boundaries. Strangely enough I can
fix them by writing the vector map to a file and reading it back in. I'm
usig grass-6.5 from the develbranch_6 branch, revision 47134.
Here is a minimal example:
## rdebug is a small raster map
wget http://www.linta.de/~hoeth/grass/rdebug.bz2
bunzip2 rdebug.bz2
r.in.ascii in=rdebug out=rdebug
r.contour rdebug out=vdebug levels=160
v.type vdebug out=vdebug_boundary
v.clean vdebug_boundary out=vdebug_boundary_clean tool=prune,break,rmdangle thresh=1,0,0,-1
v.centroids vdebug_boundary_clean out=vdebug_centroids
## Note that one of the two areas is broken
v.out.ascii vdebug_boundary_clean out=vdebug_boundary_clean format=standard
v.in.ascii vdebug_boundary_clean out=vdebug_boundary_clean2 format=standard
v.centroids vdebug_boundary_clean2 out=vdebug_centroids --o
## Now both areas get their centroid.
My region settings for this example are
projection: 99 (Mercator)
zone: 0
datum: towgs84=0,0,0,0,0,0,0
ellipsoid: a=6378137 es=0
north: 6850290
south: 6847260
west: 1561850
east: 1564380
nsres: 10
ewres: 10
rows: 303
cols: 253
cells: 76659
Any idea what's going on here or what I'm doing wrong?
Cheers,
Hendrik
