[GRASS-user] Using g.extension on Ubuntu 11.04
Glynn Clements
glynn at gclements.plus.com
Mon Jul 25 03:08:59 EDT 2011
Thomas.Adams at noaa.gov wrote:
> sudo g.extension extension=v.strahler
> I get the message:
> GRASS 6.4.1 (ffpi):~/grass/data > sudo g.extension extension=v.strahler
> [sudo] password for teaiii:
> sudo: g.extension: command not found
sudo resets the environment, including PATH. In fact, it resets PATH
even if the -E (preserve environment) option is used.
> I'm at a loss what to do. Any suggestions?
Modify the g.extension script to use sudo rather than "su -c ...".
