[GRASS-user] Using g.extension on Ubuntu 11.04
S. Koukoulas
sotkouk at gmail.com
Mon Jul 25 13:36:14 EDT 2011
I had this problem as well and I used a "user level" solution....
I started grass with sudo (sudo grass) and then created a new mapset (u
can' t have access to the previous ones) to enter grass.
After that you can install extensions without being prompted for a root
password. Then exit and enter grass as usual.
hth,
sotiris
On 07/24/2011 09:11 PM, Thomas.Adams at noaa.gov wrote:
> All:
> At the GRASS 6.4.1 prompt, when I type:
> g.extension extension=v.strahler
> v.strahler is retrieved successfully and compiles, but then I get the message:
> Installing <v.strahler>...
> You need to enter the root password next to install v.strahler:
> Password:
> The problem is, Ubuntu does not allow a root password (I don't have one) and of course my password is not acceptable. If, instead, I try:
> sudo g.extension extension=v.strahler
> I get the message:
> GRASS 6.4.1 (ffpi):~/grass/data > sudo g.extension extension=v.strahler
> [sudo] password for teaiii:
> sudo: g.extension: command not found
> I'm at a loss what to do. Any suggestions?
> Regards,
> Tom
> grass-user mailing list
> http://lists.osgeo.org/mailman/listinfo/grass-user
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110725/62516be2/attachment.html
