[GRASS-user] Using g.extension on Ubuntu 11.04
Rainer M Krug
r.m.krug at gmail.com
Tue Jul 26 03:11:25 EDT 2011
On Tue, Jul 26, 2011 at 8:49 AM, Andy Wickert <wickert at colorado.edu> wrote:
> Actually, you can create a root password in Ubuntu.
> At a command prompt:
> type "sudo su"
> Enter your sudo password
> type "passwd"
> choose your root password
True - but based on the reasoning of ubuntu, one should not do this
(apparent security implications)
Cheers,
Rainer
> Hope this helps!
> Andy Wickert
> PhD Candidate
> University of Colorado
> Geological Sciences & Institute of Arctic and Alpine Research
> 1560 30th St.
> Boulder, CO 80303
> Office: RL3-275
> On Sun, Jul 24, 2011 at 11:11 AM, <Thomas.Adams at noaa.gov> wrote:
>> All:
>> At the GRASS 6.4.1 prompt, when I type:
>> g.extension extension=v.strahler
>> v.strahler is retrieved successfully and compiles, but then I get the
>> message:
>> Installing <v.strahler>...
>> You need to enter the root password next to install v.strahler:
>> Password:
>> The problem is, Ubuntu does not allow a root password (I don't have one)
>> and of course my password is not acceptable. If, instead, I try:
>> sudo g.extension extension=v.strahler
>> I get the message:
>> GRASS 6.4.1 (ffpi):~/grass/data > sudo g.extension extension=v.strahler
>> [sudo] password for teaiii:
>> sudo: g.extension: command not found
>> I'm at a loss what to do. Any suggestions?
>> Regards,
>> Tom
>> grass-user mailing list
>> grass-user at lists.osgeo.org
>> http://lists.osgeo.org/mailman/listinfo/grass-user
Rainer M. Krug, PhD (Conservation Ecology, SUN), MSc (Conservation Biology,
UCT), Dipl. Phys. (Germany)
Centre of Excellence for Invasion Biology
Stellenbosch University
South Africa
Tel : +33 - (0)9 53 10 27 44
Cell: +33 - (0)6 85 62 59 98
Fax (F): +33 - (0)9 58 10 27 44
Fax (D): +49 - (0)3 21 21 25 22 44
email: Rainer at krugs.de
Skype: RMkrug
URL: http://lists.osgeo.org/pipermail/grass-user/attachments/20110726/4a5258b2/attachment.html
