[GRASS-user] I'm in a hole and want to stop digging, [SOLVED]
Richard Chirgwin
rchirgwin at ozemail.com.au
Wed Jul 27 16:53:36 EDT 2011
On 28/07/11 8:18 AM, grass-user-request at lists.osgeo.org wrote:
> Message: 2
> Date: Wed, 27 Jul 2011 08:24:45 -0700 (PDT)
> From: Rich Shepard<rshepard at appl-ecosys.com>
> Subject: Re: [GRASS-user] I'm in a hole and want to stop digging
> [SOLVED]
> To:grass-user at lists.osgeo.org
> Message-ID:
> <alpine.LNX.2.00.1107270822050.17199 at salmo.appl-ecosys.com>
> Content-Type: TEXT/PLAIN; charset=US-ASCII; format=flowed
> On Wed, 27 Jul 2011, Richard Chirgwin wrote:
>> > My approach - I use MySQL but don't see why this would not work in pg - is to
>> > associate a schema to a mapset. So if I want PERMANENT and Project, over in
>> > MySQL I might run:
>> > create database Master
>> > create database Project
> Richard,
> When I stepped back to look at the forest instead of the individual trees
> I appreciate that I should have understood this; except I've not before
> worked with an external database. Mea culpa!
> Since each mapset has it's own dbf/ directory for GRASS-internal vector
> attributes, each mapset needs it's own external database, too.
> g.copy now works.
> Thank you,
> Rich
Rich,
My pleasure. I remember how much pain the database parameters caused me,
when I was learning both Grass-GIS and MySQL at the same time!
Cheers,
Richard Chirgwin
