[GRASS-user] Copying Raster Map from PERMANENT to Project Mapset
Rich Shepard
rshepard at appl-ecosys.com
Fri Jul 29 09:44:22 EDT 2011
On Fri, 29 Jul 2011, Sylvain Maillard wrote:
> g.copy will copy the whole map in the new mapset. If you want to get only
> the portion of the DEM within the region of the new mapset, you will have
> to use r.mapcalc ! be carafull to proprely set the resolution to that of
> your DEM, otherwise it will be resampled and look quite bad ...
Sylvain,
Thank you.
Rich
