[GRASS-user] WinGrass nightly build problems
Daniel Victoria daniel.victoria at gmail.com
Fri Jul 29 09:49:34 EDT 2011
Hi all,
Just installed the latest wingrass nightly build [1] and I'm getting
an error when I try to select the grass database directory or when I
click on a location. Also, the mapsets for each location are not
displayed in the mapset window.
The error in the console windows is:
  File "C:\Program Files (x86)\GRASS 7.0.SVN\etc\gui\wxpython\gis_set.py", line
635, in OnSelectLocation
    self.listOfLocations[self.lblocations.GetSelection()]))
599, in UpdateMapsets
    gisdbase = self.gisdbase)
  File "c:/osgeo4w/usr/src/grass_trunk/dist.i686-pc-mingw32/etc/gui/wxpython/gui
_modules/gcmd.py", line 610, in RunCommand
_modules/gcmd.py", line 610, in <lambda>
  File "C:\Program Files (x86)\GRASS 7.0.SVN\etc\gui\wxpython\gui_modules\utils.
py", line 664, in DecodeString
    return string.decode('utf-8')
  File "C:\Program Files (x86)\GRASS 7.0.SVN\Python25\lib\encodings\utf_8.py", l
ine 16, in decode
    return codecs.utf_8_decode(input, errors, True)
UnicodeDecodeError: 'utf8' codec can't decode bytes in position 34-35: invalid d
ata
I'm using a Brazilian Portuguese version of Win7. Anyone seen this error?
Thanks
Daniel
[1] - http://wingrass.fsv.cvut.cz/grass70/
